On 10/3/23 06:07, STARRITT, Andrew wrote:
Caution: This email originated from outside of Cosylab.
Hi all,
What was the final solution here?
I tried on one of our Control Room OPI hosts.
With the client side firewall off, everything worked as expected.
With client side firewall on, I had no access, even with using pvxs.
Hi Andrew,
As Michael summarized, the PVXS *server* responds in a different (and more conformant way) than the old server based on pvAcessCPP. Meaning, using PVXS on the client won't help. The solution is rebuilding your IOC with QSRV2 [1], which is based on PVXS [2], while noting that this stuff is still experimental and that defaults could change [3]. For us, the issue arises in a staging environment for a project where we can't use QSRV2, so we weren't able to test this, but given the nature of the problem, I'm pretty sure it should work with the usual one-way firewalls. If you can give QSRV2 a test drive, it would be great, and many of us would be grateful; this stuff should get more testing.
[1] https://mdavidsaver.github.io/pvxs/ioc.html#qsrv-2
[2] https://mdavidsaver.github.io/pvxs/building.html#includepvxs
[3] https://github.com/mdavidsaver/pvxs/pull/58
Best,
Jure
- PVA connection problem Ignacio Arriagada via Tech-talk
- Re: PVA connection problem Ralph Lange via Tech-talk
- Re: PVA connection problem Jure Varlec via Tech-talk
- Re: PVA connection problem Michael Davidsaver via Tech-talk
- RE: PVA connection problem [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
RE: Use sscan with transform record coordinate motion Abdalla Ahmad via Tech-talk
Re: Use sscan with transform record coordinate motion Mark Rivers via Tech-talk
<2023>
<2023>
