1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: preventing changing an EPICS motor's commanded position
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Gregory, Ray" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 3 Oct 2023 08:16:56 -0500
Ray,
Can you provide more details about what "disabling the axis" means? The behavior of the motor record's CNEN field, which is labeled "Torque" on the motorx_all screen, is controller dependent; for some controllers CNEN enables/disables drive power, for other controllers CNEN switches between open and closed loop control, and some drivers do nothing when CNEN is changed.
Kevin
On 10/2/23 12:32, Gregory, Ray via Tech-talk wrote:
How can I prevent changing an EPICS motor record’s commanded position (.VAL field) without disabling the axis?
Thank you,
Ray
Ray Gregory
Oak Ridge National Laboratory
RE: [EXTERNAL] Re: preventing changing an EPICS motor's commanded position Gregory, Ray via Tech-talk
Re: preventing changing an EPICS motor's commanded position Matt Newville via Tech-talk
Prev: Re: Use sscan with transform record coordinate motion Mark Rivers via Tech-talk
Next: RE: [EXTERNAL] Re: preventing changing an EPICS motor's commanded position Gregory, Ray via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: preventing changing an EPICS motor's commanded position Johnson, Andrew N. via Tech-talk
