1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: preventing changing an EPICS motor's commanded position
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Gregory, Ray" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 2 Oct 2023 17:58:40 +0000
Hi Ray,
This might not be what you’re looking for, but you can prevent all remote puts to any field of a record by setting its DISP field to a non-zero value. Local DB links can still write to the record and it will still process normally, but any puts to it through CA or PVA should fail (except for puts to the DISP field, so you can undo that remotely).
You could also look at setting up Access Security which can limit when, who and from where puts will be allowed, but this is a more involved change, consult a local expert about that.
- Andrew
Complexity comes for free, Simplicity you have to work for.
From: Tech-talk <[email protected]> on behalf of Gregory, Ray via Tech-talk <[email protected]>
Date: Monday, October 2, 2023 at 12:32 PM
To: [email protected] <[email protected]>
Subject: preventing changing an EPICS motor's commanded position
How can I prevent changing an EPICS motor record’s commanded position (.VAL field) without disabling the axis?
Thank you,
Ray
Ray Gregory
Oak Ridge National Laboratory
preventing changing an EPICS motor's commanded position Gregory, Ray via Tech-talk
Prev: preventing changing an EPICS motor's commanded position Gregory, Ray via Tech-talk
Next: Re: Multiple layers of DB templates? Gregory, Ray via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: preventing changing an EPICS motor's commanded position Kevin Peterson via Tech-talk
