Subject: |
Re: How to use INSTALL_LOCATION with system directories |
Jure Varlec via Tech-talk <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 9 Oct 2023 17:03:09 +0200 |
On 10/9/23 16:15, Lucas Russo via
Tech-talk wrote:
Caution: This email
originated from outside of Cosylab.
Hi Ralph, Abdalla,
I understand. Because there's no separate "installation
phase" it
doesn't seem possible to achieve what I was thinking.
Lucas
Hi Lucas,
Why not? Unless I misunderstood what you want, you could do
make
INSTALL_LOCATION=${HOME}/tmp/staging/ FINAL_LOCATION=/opt/test
sudo mv
${HOME}/tmp/staging/ /opt/test
sudo chown -R
epics:epics /opt/test #
Or root, or whatever
Perhaps having the staging directory under $(TOP) or /tmp makes
more sense, it depends on your case, but you get the idea. Would
this work for you?
Best,
Jure
- Re: How to use INSTALL_LOCATION with system directories Ralph Lange via Tech-talk
- Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
- How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
