1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: How to use INSTALL_LOCATION with system directories
From: Lucas Russo via Tech-talk <[email protected]>
To: Jure Varlec <[email protected]>
Cc: [email protected]
Date: Tue, 10 Oct 2023 09:01:45 +0200
Hi Jure,
Yes. I could do that, but the point was to use the mechanism already in place
in the EPICS build system. I thought "INSTALL_LOCATION" would be enough,
but because there's no separate "build" and "install" phases, it doesn't really
work to compile sources with one user and install with another.
Basically, I thought I could do the "autotools" style installation.
Lucas
On Mon, Oct 9, 2023 at 5:03 PM Jure Varlec via Tech-talk <[email protected]> wrote:
On 10/9/23 16:15, Lucas Russo via Tech-talk wrote:
Caution: This email originated from outside of Cosylab.
Hi Ralph, Abdalla,
I understand. Because there's no separate "installation phase" it
doesn't seem possible to achieve what I was thinking.
Lucas
Hi Lucas,
Why not? Unless I misunderstood what you want, you could do
make INSTALL_LOCATION=${HOME}/tmp/staging/ FINAL_LOCATION=/opt/test
sudo mv ${HOME}/tmp/staging/ /opt/test
sudo chown -R epics:epics /opt/test  # Or root, or whatever
Perhaps having the staging directory under $(TOP) or /tmp makes more sense, it depends on your case, but you get the idea. Would this work for you?
Best,
Jure
How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Ralph Lange via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Jure Varlec via Tech-talk
Prev: Re: How to use INSTALL_LOCATION with system directories Ralph Lange via Tech-talk
Next: Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Next: Cross Compilation of Epics-base nsrivastava via Tech-talk
