1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: How to use INSTALL_LOCATION with system directories
From: Lucas Russo via Tech-talk <[email protected]>
To: Maren Purves <[email protected]>
Date: Tue, 10 Oct 2023 09:07:47 +0200
Hi Maren,
I think my question is why not? That's one usual place where you
install binaries/libaries in a linux system that is not a package
(.deb, .rpm). To my knowledge the recommendation is /usr/local
for "local" packages.
Lucas
On Mon, Oct 9, 2023 at 8:25 PM Maren Purves via Tech-talk <[email protected]> wrote:
The part I don't understand is why you want to install it in system space in the first place.
We never have. Install it somewhere you have write access to and add that to your $PATH?
Maren Purves
Head of Instrument and Telescope Software
East Asian Observatory/JCMT
On Mon, Oct 9, 2023 at 5:28 AM Ralph Lange via Tech-talk <[email protected]> wrote:
On Mon, 9 Oct 2023 at 17:03, Jure Varlec via Tech-talk <[email protected]> wrote:
On 10/9/23 16:15, Lucas Russo via Tech-talk wrote:
Caution: This email originated from outside of Cosylab.
Hi Ralph, Abdalla,
I understand. Because there's no separate "installation phase" it
doesn't seem possible to achieve what I was thinking.
Lucas
Hi Lucas,
Why not? Unless I misunderstood what you want, you could do
make INSTALL_LOCATION=${HOME}/tmp/staging/ FINAL_LOCATION=/opt/test
sudo mv ${HOME}/tmp/staging/ /opt/test
sudo chown -R epics:epics /opt/test  # Or root, or whatever
Perhaps having the staging directory under $(TOP) or /tmp makes more sense, it depends on your case, but you get the idea. Would this work for you?
Or, if you really want to use make, you can obviously use INSTALL_LOCATION for your staging area, FINAL_LOCATION for the target area and add something like
final-install:
       mkdir -p $(FINAL_LOCATION); cp -a $(INSTALL_LOCATION)/* $(FINAL_LOCATION)
to the end of your top Makefile.
Cheers,
~Ralph
How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Ralph Lange via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Jure Varlec via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Maren Purves via Tech-talk
Prev: Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Next: Re: How to use INSTALL_LOCATION with system directories Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: How to use INSTALL_LOCATION with system directories Maren Purves via Tech-talk
Next: RE: How to use INSTALL_LOCATION with system directories Abdalla Ahmad via Tech-talk
