1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: creating soft channel ioc to interface with real ioc
To: "Tran, Phi Dung" <[email protected]>
Date: Wed, 11 Oct 2023 12:54:18 +0000
Your IOC application needs to be built with the DBD and library file from the EPICS motor module. Add lines like this to your application Makefile:
MyApp_DBD   += motorSupport.dbd
 MyApp_LIBS := motor (MyApp_LIBS)
If you are using the Galil driver then also add lines like this:
 MyApp_DBD   += GalilSupport.dbd
 MyApp_LIBS := GalilSupport (MyApp_LIBS)
You need to add the paths to those modules to your application configure/RELEASE file as well.
On Oct 11, 2023, at 7:28 AM, Tran, Phi Dung via Tech-talk <[email protected]> wrote:
I am a EPICS beginner.  I created an motor ioc and interfaced it successfully using CSS on three different occasions.
Next I tried to create a soft ioc to move my motors in the previous real motor ioc.
I am trying to create a soft ioc, I got this error message but could not figure out.
ecord "XF:19IDC-ES-G0{MD2:Pitch}Mtr" is of unknown type "motor"
Error at or before ")" in file "../../db/galil0_pitch.db" line 20
Error: syntax error
Do you have any suggestions.
Thank you kindly for your help,
Alex
<galil0_pitch.db>
<galil0_Ymove_ib_ob_ds.db>
creating soft channel ioc to interface with real ioc Tran, Phi Dung via Tech-talk
Prev: creating soft channel ioc to interface with real ioc Tran, Phi Dung via Tech-talk
Next: Re: Job Oppotunity BESSY II Control Systems Engineer ROCK-IT Project Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: process multiple lines with streamdevice Gerrit Kühn via Tech-talk
