1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: process multiple lines with streamdevice
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 13 Oct 2023 12:53:43 +0000
Hi Gerrit,
If you do not set your InTerminator to the normal line terminator for this
protocol (i.e. inside the { } ), then the 'in' command will read all the lines
(terminated by readTimeout). If there is a "special" terminator after reply
(e.g. 2 newlines) even better: Set InTerminator accordingly.
Now you can parse for your unique identifier with a regex search.
ExtraInput=ignore;
in "%/unique identifier[^\n]*/";
This should give you the matching line (as a string).
or
in "%.1/unique identifier/([\n]*)";
should give you everything after the the identifier.
To read a number after the identifier:
in "%*/unique identifier/%f)";
Or several numbers:
in "%*/unique identifier/%(\$1:rec1)f,%(\$1:rec1)f,%f";
%/regex/ searches the a match (skipping everything before) and returns the
match. %.n/regex/ returns the match for the n-th () in the regex.
%*/regex/ skips the match (returns nothing) and lets you continue parsing for
data right after the match.
Give example data for more details (so that I do not have to guess).
Dirk
On Fri, 2023-10-13 at 14:15 +0200, Gerrit Kühn via Tech-talk wrote:
> Hello,
> I have a couple of devices on a bus. I can get a list of the devices and
> their properties using an enumeration call. I am interested in some of
> these properties and the answer line for a particular device would be easy
> to parse with streamdevice. However, the answer for the whole bus consists
> of several of these lines while I am only looking for one (and I know how
> it starts, containing an unique device identifier).
> Is there some way to do this with streamdevice or to I need a different
> approach? I cannot use the recommended solution from the "Tips&Tricks"
> section of the manual and use multiple IN-statements as I do neither know
> how many of these there will be, nor the number of the one I am looking
> for.
> cu
>   Gerrit
Re: process multiple lines with streamdevice Gerrit Kühn via Tech-talk
Prev: process multiple lines with streamdevice Gerrit Kühn via Tech-talk
Next: Re: process multiple lines with streamdevice Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
