I haven't seen any replies to your question here yet. I know many of our core developers have been at the ICALEPCS-2023 conference, and I'm on vacation this week and next, so my apologies if you're still
waiting for help.
Unfortunately we don't have detailed documentation that answers your question (I agree that we should), but the majority of the configuration needed to set up your cross-builds may have already been done.
You haven’t said what your host architecture is, I hope it's Linux on 32- or 64-bit x86 or amd64, and that your target will be running under Linux.
Assuming those are correct you would start by editing the file base-7.0.7/configure/os/CONFIG_SITE.linux-x86.linux-arm and change the GNU_DIR variable there to point to the prefix of where your cross-compiler
has been installed — the EPICS build system looks in $(GNU_DIR)/bin for the cross-compiler.
Then edit the base-7.0.7/configure/CONFIG_SITE file and set CROSS_COMPILER_TARGET_ARCHS to linux-arm. You don't need to make any other changes in those files for now.
With those settings you can try running "make" in the base-7.0.7/configure directory. That should create the directories O.linux-x86_64 and O.linux-arm, and inside each of those it will try to run the C
Preprocessor for that target. If you don't see the build in the O.linux-arm directory running your cross-compiler's preprocessor you will have to make some additional configuration changes, but you should copy the command-line it runs and any errors you get
into a post to this mailing list for help at that stage.
If it did the right thing, cd to the base-7.0.7 directory and run "make" from there to see how far the build gets. Again if you see errors please copy & paste them into an email here (don't paste a screen-dump
image, text only).
The more detail about your configuration and the errors you're seeing that you send to this list, the easier it will be for us to help.
- Andrew
I have created a cross toolchain using Yocto (Kirkstone branch) for Nvidia Jetson Xavier NX development kit. I am trying to compile epics-base-7.0.7 version (https://epics.anl.gov/download/base/base-7.0.7.tar.gz)
using the cross toolchain for arm architecture.
I am unable to find any clear instruction to cross compile epic 7.0.7 for any other architecture. It would be helpful to guide me through the link to document or any related information. Thank you
Regards
NSrivastava
This email and any files transmitted with it
are company confidential, meant for the sole
use of the intended recipient. Any use or
dissemination of this email by others is strictly
prohibited. If you are not the intended recipient,
please contact the sender immediately.
