It sounds like this is a routing issue for you, your Ophyd link works for me (and my comment above about lower-casing your links was apparently another "feature" of MS Outlook that I'm forced to use now).
- Andrew
Complexity comes for free, Simplicity you have to work for.
Marco A. Barra Montevechi Filho <marco.filho at lnls.br>
Date: Monday, October 23, 2023 at 10:11 AM
To: Johnson, Andrew N. <anj at anl.gov>, tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: Is areaDetector documentation down?
Andrew, thanks for the answer!
None of the links provided in your email work for me.
It might be something with github?
Marco
Sent: 23 October 2023 11:44
To: Marco A. Barra Montevechi Filho <marco.filho at lnls.br>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Marco,
The master index page at
https://areadetector.github.io/master/index.html is working for me; your link seems to have been lower-cased which probably won't work, try this one instead for the NDPluginDriver:
https://areadetector.github.io/master/ADCore/NDPluginDriver.html
- Andrew
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Marco A. Barra Montevechi Filho via Tech-talk <tech-talk at aps.anl.gov>
Date: Monday, October 23, 2023 at 7:01 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Is areaDetector documentation down?
Good morning all, i have been trying to access the documentation in
https://areadetector.github.io/master/ since last week. Did something happen to it? Is there any other good source for the latest versions?
att,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes
de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before
copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Is areaDetector documentation down? Marco A. Barra Montevechi Filho via Tech-talk
- Re: Is areaDetector documentation down? Johnson, Andrew N. via Tech-talk
- Re: Is areaDetector documentation down? Marco A. Barra Montevechi Filho via Tech-talk
Re: Is areaDetector documentation down? Pete Jemian via Tech-talk
<2023>
Re: Is areaDetector documentation down? Maren Purves via Tech-talk
<2023>
ANJ, 23 Oct 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
