1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: PVList in C++ API
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Eusebio Naif Al-Soliman Fuentes <eunaif at correo.ugr.es>
Cc: Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 23 Oct 2023 12:18:10 -0700
On 10/23/23 06:42, Eusebio Naif Al-Soliman Fuentes via Tech-talk wrote:
Hello everybody.
I have a small question regarding the C++ API (https://docs.epics-controls.org/projects/pvaccess-cpp/en/latest/doxygen/index.html) <https://docs.epics-controls.org/projects/pvaccess-cpp/en/latest/doxygen/index.html>
I want to do the equivalent operation to 'pvlist' in order to get all the IOCs in my network and also get all the variables declared in each IOC (pvlist <GUID>). Is there any method implemented in the C++ API to do that? Which one?
pvAccessCPP does not expose an API which could be used to build "pvlist".
PVXS does expose pvxs::client::Context::discover() which is used to build
the "pvxlist" executable.
https://github.com/mdavidsaver/pvxs/blob/master/tools/list.cpp
https://mdavidsaver.github.io/pvxs/client.html#_CPPv4N4pvxs6client7Context8discoverERRNSt8functionIFvRK10DiscoveredEEE
I must give a word of warning.  Frequent pinging of all servers, and
querying of all PV names, can generate considerable load.
Please be careful that you don't DDoS your own network!
Thanks in advance.
Saludos/Best regards
*University of Granada *
*MSc. Data Science and Computer Engineering*__
Re: PVList in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
Prev: "invalid output sync mutex" and ci-scripts on windows Michael Davidsaver via Tech-talk
Next: Re: Is areaDetector documentation down? Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: PVList in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
Next: Re: PVList in C++ API Eusebio Naif Al-Soliman Fuentes via Tech-talk
ANJ, 25 Oct 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
