Not an answer to your question, but... That library you are using is part of the first generation of user-facing libraries. Meanwhile, there's a second generation (both for C++ and Java) with more modern and language-specific API designs. Better usability, easier to work with, better performance. These second-generation libraries are stable; they will be replacing the older generation. For your use case: The C++ second-generation library is called PVXS - https://mdavidsaver.github.io/pvxs/ For any new development - please start there. It will save you from migrating your application at some point in the near future. Cheers, ~Ralph On Thu, 2 Nov 2023 at 12:46, Eusebio Naif Al-Soliman Fuentes via Tech-talk <[email protected]> wrote:
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
