While compiling either of quadEM-R9-2-1 or quadEM-R9-4 with EPICS bas-7.0.7 in Centos 9 Stream, I was getting the following narrowing conversion error:
../drvTetrAMM.cpp: In member function ‘void drvTetrAMM::readThread()’:
../drvTetrAMM.cpp:268:22: error: narrowing conversion of ‘18443366386873925631’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
268 | case 0xfff40002ffffffffll:
../drvTetrAMM.cpp:273:22: error: narrowing conversion of ‘18443366378283991039’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
273 | case 0xfff40000ffffffffll:
../drvTetrAMM.cpp:283:22: error: narrowing conversion of ‘18443366382578958335’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
283 | case 0xfff40001ffffffffll:
../drvTetrAMM.cpp:296:22: error: narrowing conversion of ‘18443366391168892927’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
296 | case 0xfff40003ffffffffll:
make[3]: *** [/usr/local/epics/base/configure/RULES_BUILD:267: drvTetrAMM.o] Error 1
make[3]: Leaving directory '/home/epics/chemmatCARS/synApps/support/quadEM-R9-4/quadEMApp/src/O.linux-x86_64'
make[2]: *** [/usr/local/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/epics/chemmatCARS/synApps/support/quadEM-R9-4/quadEMApp/src'
make[1]: *** [/usr/local/epics/base/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/home/epics/chemmatCARS/synApps/support/quadEM-R9-4/quadEMApp'
make: *** [/usr/local/epics/base/configure/RULES_DIRS:85: quadEMApp.install] Error 2
I resolved the errors by changing line #193 of quadEM-R9-2-1 or line #191 of quadEM-R9-4 from
long long lastValue;
to
unsigned long long lastValue;
I hope this will be helpful to someone getting similar errors.
Mrinal
