1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Olog usage
From: Timo Korhonen via Tech-talk <[email protected]>
To: "Jarosz, Dariusz Piotr" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Xiao, Lingran" <[email protected]>, "Chandler, Elaine" <[email protected]>
Date: Tue, 7 Nov 2023 15:39:39 +0000
We at ESS use olog (Phoebus) heavily, 24/7 in the control room. Migrated from PSI elog a couple of years ago.
There are ~10 logbooks in total of which a few are in daily use.
Used by
  • Operations
  • Cryo
  • RF
  • And other disciplines.
I hope this helps.
Timo (@ European Spallation Source ERIC)
From: Tech-talk <[email protected]> on behalf of "Jarosz, Dariusz Piotr via Tech-talk" <[email protected]>
Reply to: "Jarosz, Dariusz Piotr" <[email protected]>
Date: Tuesday, 7 November 2023 at 04:24
Subject: Olog usage
Hi All,
We are preparing a presentation about olog and we wanted to gather some information about how olog is used at different facilities.
  • Is it used at your facility?
    • How heavily is it used?
    • Who is using it?
Thank you,
Dariusz
Olog usage Jarosz, Dariusz Piotr via Tech-talk
Prev: Resolved narrowing conversion error while compiling quadEM module Mrinal Bera via Tech-talk
Next: labjack support, command not found Wolfman, Mark via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Olog usage Jarosz, Dariusz Piotr via Tech-talk
Next: A Modbus problem relating to byte order and endian Chiang, Liang-Chih [江良志] via Tech-talk
