Hi Mark,
You should remove that line. That line is in the example st.cmd files in Labjack because they are initializing the IOC. But when you put Labjack support in another IOC your st.cmd will already have called xxxAppRegisterRecordDeviceDriver for your application.
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Wolfman, Mark via Tech-talk
Sent: Tuesday, November 7, 2023 10:07 AM
To: tech-talk at aps.anl.gov
Subject: labjack support, command not found
Hi, all.
I'm using the epics labjack module v3.0.0 and trying to include it in an existing IOC. I downloaded it from git (commit 61e3c59d91a721ccef8f5504cb1ba4cab5e0cba8) and modified it to build from APSshare since I don't have a corvette. The separate IOC builds fine and the labjack seems to work, but there is this error message in the IOC console:
> LabJack.cmd line 13: Command LabJackApp_registerRecordDeviceDriver not found.
which references the line ``LabJackApp_registerRecordDeviceDriver(pdbbase)``
I'm not clear on what this command does. Can I fix this error somehow, or else can I safely remove that offending line since the IOC seems to work as expected?
Here's the lines that I added to st.cmd: https://gist.github.com/canismarko/e4bc0c61fcf7c5b4803d69a7a691cb30
based on: https://github.com/epics-modules/LabJack/blob/master/iocBoot/iocLabJack_T7/st.cmd
My work schedule may not be the same as your work schedule. Please don't feel obligated to respond to this e-mail outside of your normal work hours.
- Re: labjack support, command not found Wolfman, Mark via Tech-talk
- labjack support, command not found Wolfman, Mark via Tech-talk
Re: Resolved narrowing conversion error while compiling quadEM module Mrinal Bera via Tech-talk
<2023>
<2023>
