1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: Resolved narrowing conversion error while compiling quadEM module
From: Mrinal Bera via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: Tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 7 Nov 2023 16:37:29 +0000
Thanks, Mark. I see the commit now.
Mrinal
On Nov 7, 2023, at 10:28 AM, Mark Rivers <rivers at cars.uchicago.edu> wrote:
Hi Mrinal,
That warning was already fixed in this commit from September 2022.
R9-4 is from November 2020, so this commit is only present on the master branch.  I recommend you use the master branch for now, until I have a chance to make a new release.
When you run into a problem like this it is always a good idea to check the master branch to see if it has already been fixed.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mrinal Bera via Tech-talk
Sent: Tuesday, November 7, 2023 9:37 AM
To: Tech-talk <tech-talk at aps.anl.gov>
Subject: Resolved narrowing conversion error while compiling quadEM module
Dear friends,
While compiling either of quadEM-R9-2-1 or quadEM-R9-4 with EPICS bas-7.0.7 in Centos 9 Stream, I was getting the following narrowing conversion error:
../drvTetrAMM.cpp: In member function ‘void drvTetrAMM::readThread()’:
../drvTetrAMM.cpp:268:22: error: narrowing conversion of ‘18443366386873925631’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
  268 |                 case 0xfff40002ffffffffll:
../drvTetrAMM.cpp:273:22: error: narrowing conversion of ‘18443366378283991039’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
  273 |                 case 0xfff40000ffffffffll:
../drvTetrAMM.cpp:283:22: error: narrowing conversion of ‘18443366382578958335’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
  283 |                 case 0xfff40001ffffffffll:
../drvTetrAMM.cpp:296:22: error: narrowing conversion of ‘18443366391168892927’ from ‘long long unsigned int’ to ‘long long int’ [-Wnarrowing]
  296 |                 case 0xfff40003ffffffffll:
make[3]: *** [/usr/local/epics/base/configure/RULES_BUILD:267: drvTetrAMM.o] Error 1
make[3]: Leaving directory '/home/epics/chemmatCARS/synApps/support/quadEM-R9-4/quadEMApp/src/O.linux-x86_64'
make[2]: *** [/usr/local/epics/base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/home/epics/chemmatCARS/synApps/support/quadEM-R9-4/quadEMApp/src'
make[1]: *** [/usr/local/epics/base/configure/RULES_DIRS:85: src.install] Error 2
make[1]: Leaving directory '/home/epics/chemmatCARS/synApps/support/quadEM-R9-4/quadEMApp'
make: *** [/usr/local/epics/base/configure/RULES_DIRS:85: quadEMApp.install] Error 2
I resolved the errors by changing line #193 of quadEM-R9-2-1 or line #191 of quadEM-R9-4 from
long long lastValue;
to
unsigned long long lastValue;
I hope this will be helpful to someone getting similar errors.
Mrinal
Resolved narrowing conversion error while compiling quadEM module Mrinal Bera via Tech-talk
RE: Resolved narrowing conversion error while compiling quadEM module Mark Rivers via Tech-talk
Prev: RE: Resolved narrowing conversion error while compiling quadEM module Mark Rivers via Tech-talk
Next: RE: labjack support, command not found Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: labjack support, command not found Wolfman, Mark via Tech-talk
ANJ, 07 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
