Hi Jesse, Sorry for the delay. What I do is fairly simple. For each sensor, I load a small record into a softIOC with dbLoadRecords("esensor.db","P=13IDE:,Q=Esensor") in the startup script and with the "esensor.db" of (also attached): #### # record used for Esensor temperature, humidity sensors record(ai,"$(P)$(Q):TempF") { field(DESC, "Temperature (F)") field(VAL, "0") } record(ai,"$(P)$(Q):TempC") { field(DESC, "Temperature (C)") field(VAL, "0") } record(ai,"$(P)$(Q):Humid") { field(DESC, "Humidity (percent)") field(VAL, "0") } record(stringin, "$(P)$(Q):TimeStamp") { field(DESC, "Timestamp of last update") field(VAL, "") } #### Then, I run a Python script (attached) to read the sensor (over plain HTTP), parse the results, and push to PVs. The script handles both older Esensors that send data as XML, and newer ones that send JSON data. You could probably put that script inside procServ or something like that but I just have it running as a simple background script. --Matt On Fri, Nov 10, 2023 at 4:15 PM Jesse Hopkins <jhopkins1 at iit.edu> wrote:
--Matt Newville <newville at cars.uchicago.edu> 630-327-7411 Attachment:
esensor.db #!/usr/bin/env python import requests import time import json import xml.etree.ElementTree as ET from epics import get_pv class ESensor: """ read Esensor data, push to Epics PVs""" def __init__(self, label, url, prefix, format="xml"): self.label = label self.url = url self.prefix = prefix self.format = format self.tempf_pv = get_pv(f"{prefix:s}:TempF.VAL") self.tempc_pv = get_pv(f"{prefix:s}:TempC.VAL") self.humid_pv = get_pv(f"{prefix:s}:Humid.VAL") self.timestamp_pv = get_pv(f"{prefix:s}:TimeStamp.VAL") self.tattr = "tm0" self.tunit = "tun0" self.hattr = "hu0" self.reader = ET.fromstring if format == "json": self.tattr = "tmp" self.hattr = "hum" self.tunit = "tun" self.reader = json.loads def getval(self, source, attr, force_float=True): if self.format == "xml": try: val = source.find(attr).text except: val = "-1" elif self.format == "json": try: val = source.get(attr, -1.0) except: val = "-1" if force_float: try: val = float(val) except: val = -1.0 return val def read(self): resp = requests.get(self.url, timeout=0.25) tdat = self.reader(resp.content.decode("utf-8")) tunt = self.getval(tdat, self.tunit, force_float=False) tval = self.getval(tdat, self.tattr) hval = self.getval(tdat, self.hattr) return tval, tunt, hval def update(self): tval, tunit, hval = self.read() if tunit in (0, '0', 'F'): tval_f = tval tval_c = (tval - 32)*5.0/9.0 else: tval_c = tval tval_f = (tval_c * 9.0/5) + 32 tval_f = float("%.3f" % tval_f) tval_c = float("%.3f" % tval_c) hval = float("%.3f" % hval) if self.tempf_pv.connected: self.tempf_pv.put(tval_f) self.tempc_pv.put(tval_c) self.humid_pv.put(hval) self.timestamp_pv.put(time.ctime()) print(time.ctime(), self.label, tval_c, hval) # if __name__ == '__main__': esensors = [ESensor("13-ID-E", "http://164.54.160.168/sensorLogUpdate.xml", "13IDE:Esensor", format="xml"), ESensor("13-ID-C", "http://10.54.160.76/status.json", "13IDC:Esensor", format="json"), ] while True: try: [e.update() for e in esensors] except: pass time.sleep(0.5)
ANJ, 13 Nov 2023 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
