Hi, I'm having a problem with alarm-servers. I've attached the error. Phoebus shows normal when I execute the ./alarm-server.sh directly in the terminal, but it shows ‘No Alarm Server Connection’ when I use the alarms.service file for autostart. At the same time, I find it strange that the alarm config file can be imported successfully. It seems that the alarm-server can connect to Phoebus, but PV cannot. The PV data is incorrect, and what is the reason for this?
The alarms.server file is as follows:
[Unit]
After=network.target kafka.target
Requires=zookeeper.service
Requires=kafka.service
[Service]
User=sysadmin
Type=simple
ExecStart=/opt/alarm/phoebus/services/alarm-server/alarm-service.sh -settings /opt/alarm/phoebus/services/alarm-server/settings.ini
WorkingDirectory=/opt/alarm/phoebus/services/alarm-server/
RemainAfterExit=true
[Install]
WantedBy=multi-user.target ![]()
Thanks, xiaomin Attachment:
ANJ, 30 Nov 2023 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
