Hi Gerrit, You cannot point a link field at another link field. If you set in the second record field (INPA, "$(CHAN)_DUTY_CYC.A") you should get what you want. - rolf - On 2023-11-22 8:07 a.m., Gerrit Kühn
via Tech-talk wrote:
Am Wed, 22 Nov 2023 16:23:29 +0100 schrieb Gerrit Kühn via Tech-talk <tech-talk at aps.anl.gov>:You need to put PP at the end of your OUT link to force the second record to process.Yes, that was the mssing bit. Thanks to both of you for pointing this out to me.Last question for today (hopefully). I have these records now: --- record (calcout, "$(CHAN)_DUTY_CYC") { field (DESC, "duty cycled output") field (VAL, "10") # 1st cycle time field (INPA, "10") # cycle time field (CALC, "VAL-1") field (OUT, "$(CHAN)_DUTY_RESET PP") field (OOPT, "Transition To Zero") field (SCAN, "1 second") } record (calcout, "$(CHAN)_DUTY_RESET") { field (DESC, "reset cycle counter") field (VAL, "11") field (INPA, "$(CHAN)_DUTY_CYC.INPA") field (CALC, "A") field (OUT, "$(CHAN)_DUTY_CYC") field (SCAN, "Passive") } --- The second record gets processed when the counter in the first record reaches zero. However, it only resets the counter as desired when the INPA field in the second record is defined constant (i.e., INPA, "10" directly in the second record). My original idea as written above was to get the INPA field of the second record from the INPA field of the first record. However, this does not work. camonitor reports this as "LINK INVALID" although I can use caget on the reported link just fine (and get the correct value). Again, this feels like I'm missing a simple thing... cu Gerrit --
Rolf Keitel, Ph.D. Researcher Emeritus e-mail: rolf at triumf.ca ------ Home ------ 4158 West 13th Ave Vancouver, BC, V6R 2T6 604 228 0594 ------ Office: ------ 604 222 7453 TRIUMF Canada’s particle accelerator centre 4004 Wesbrook Mall Vancouver, BC, V6T 2A3 www.triumf.ca | Twitter | Facebook | Instagram TRIUMF is located on the traditional, ancestral, and unceded territory of the xʷməθkʷəy̓əm (Musqueam) people, who for millennia have passed on their culture, history, and traditions from one generation to the next on this site.
ANJ, 23 Nov 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
