Am Thu, 23 Nov 2023 09:42:49 +0000
schrieb Žiga Oven <ziga.oven at cosylab.com>:
Hello Žiga,
> My suggestion would still be to have a dedicated record that holds the
> duration value (and is appropriately named and thus better documented
> than just a field in the record) and maybe have calcout record read the
> value and push it to the counter record when the reset happens.
Great idea, I can sinply remove the OUT fields from the AO records and
use one of the RESET records for getting things started (setting PINI
there). This avoid all problems.
> With this you can also limit the user to enter the length of the
> countdown to the allowed range only, by specifying the DRVH and DRVL
> values of the AO record.
Yes, that is certainly a benefit. I had tried that before, but I couldn't
get changes in the timing values propagated only on reset time. But with
the small change above this works just fine now. Thanks for hinting me
into the right direction!
cu
Gerrit
smime.p7s
Description: S/MIME cryptographic signature
- Re: "duty cycle" records Rolf Keitel via Tech-talk
- "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Ralph Lange via Tech-talk
- Re: "duty cycle" records Gerrit Kühn via Tech-talk
- Re: "duty cycle" records Mark Rivers via Tech-talk
- RE: "duty cycle" records Žiga Oven via Tech-talk
<2023>
<2023>
