1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL
From: Carsten Winkler via Tech-talk <[email protected]>
Date: Fri, 24 Nov 2023 10:43:35 +0100
Hi Ralph!
Thank you for the quick check. I am obviously mistaken here. I had created two instances of a SoftIOC under Docker. However, only the variables of one instance were accessible on the host. I then opened the WSL session without Docker to find the problem. This is where I came across the problem mentioned in the subject line. However, my association that SoftIOC does not work in principle under Windows with Docker was wrong. Only several instances of SoftIOC do not work under Docker in such a way that they can be accessed externally.
Best,
Carsten
Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Ralph Lange via Tech-talk
Prev: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Ralph Lange via Tech-talk
Next: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) Michael Davidsaver via Tech-talk
