1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 24 Nov 2023 11:09:14 +0100
On Fri, 24 Nov 2023 at 10:43, Carsten Winkler via Tech-talk <[email protected]> wrote:
... Only several instances of SoftIOC do not work under Docker in such a way that they can be accessed externally.
Isn't that the common problem under Linux that only the last started IOC is seen when using directed UDP name resolution messages? [1] Or is that also true for broadcasts in that setup?
Note that in such a setup "external" can be outside the container (still on the same WSL2 instance), outside of the WSL2 instance (from another WSL2 instance on the same Windows host), outside of WSL2 (still on the same Windows host) or outside of the Windows host...
FWIW: Under WSL2, the internal network architecture has changed. The Windows host is now treating connections from the WSL2 network as extern, not as local.
Cheers,
~Ralph
Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
Prev: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
Next: Initialization counterpart for stopping IOCs Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Carsten Winkler via Tech-talk
