1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7
From: Carsten Winkler via Tech-talk <[email protected]>
Date: Fri, 24 Nov 2023 08:32:20 +0100
Hello!
I followed the instructions "Installation using plain Windows and the Visual Studio compilers" (https://docs.epics-controls.org/en/latest/getting-started/installation-windows-plain.html) to build the EPICS Base 7.0.7 under Windows 10. Although I had already done this successfully many times, this time the Make process always aborted with the pvAccess tools. So I took a closer look and found out the following. The current Perl Strawberry distribution (5.38.0.1) comes with Make version 4.4.1. This Make always aborts after compiling "base\modules\pvData\src\json\parseinto.cpp". The "parseinto.obj" is still created successfully. The "print.obj" should then be compiled. But instead, Make only outputs "obj = '' " and fails in the subsequent link process due to the missing "print.obj".
However, if I build the same sources with Make version 4.2.1, the entire build process runs without errors and the pvAccess tools are also built completely. All works fine.
Unfortunately I could not find out why Make 4.4.1 fails to compile "parseinto.cpp" and Make 4.2.1 has no problems with it.
Best,
Carsten
Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Ralph Lange via Tech-talk
Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 NICOLE Remi via Tech-talk
Prev: Re: "duty cycle" records Gerrit Kühn via Tech-talk
Next: Re: "duty cycle" records Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Ralph Lange via Tech-talk
Next: Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Ralph Lange via Tech-talk
