1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7
From: NICOLE Remi via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 28 Nov 2023 08:54:11 +0000
Hello!
This is probably not directly related to your issue, but I've also
encountered issues with epics-base and Make 4.4+[1].
This was fixed in d87fd0d[2], but it is not in any tagged release yet.
You might encounter this issue if your build goes further.
[1]: https://github.com/epics-base/epics-base/pull/395
[2]:
https://github.com/epics-base/epics-base/commit/d87fd0db0124faf450cff93226ae6a2cc02f02bf
Cheers!
Rémi NICOLE <remi.nicole at cea.fr>
CEA/DRF/IRFU/DIS/LDISC
On Fri, 2023-11-24 at 08:32 +0100, Carsten Winkler via Tech-talk wrote:
> Hello!
> I followed the instructions "Installation using plain Windows and the
> Visual Studio compilers"
> (https://docs.epics-controls.org/en/latest/getting-started/installati
> on-windows-plain.html) to build the EPICS Base 7.0.7 under Windows
> 10. Although I had already done this successfully many times, this
> time the Make process always aborted with the pvAccess tools. So I
> took a closer look and found out the following. The current Perl
> Strawberry distribution (5.38.0.1) comes with Make version 4.4.1.
> This Make always aborts after compiling
> "base\modules\pvData\src\json\parseinto.cpp". The "parseinto.obj" is
> still created successfully. The "print.obj" should then be compiled.
> But instead, Make only outputs "obj = '' " and fails in the
> subsequent link process due to the missing "print.obj".
> However, if I build the same sources with Make version 4.2.1, the
> entire build process runs without errors and the pvAccess tools are
> also built completely. All works fine.
> Unfortunately I could not find out why Make 4.4.1 fails to compile
> "parseinto.cpp" and Make 4.2.1 has no problems with it.
> Best,
> Carsten
GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Carsten Winkler via Tech-talk
Prev: Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Heesterman, Peter via Tech-talk
Next: Re: Simulated limit switches on motorSim motor Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Michael Davidsaver via Tech-talk
Next: Re: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Heesterman, Peter via Tech-talk
ANJ, 28 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
