1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: "duty cycle" records
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Rolf Keitel via Tech-talk <[email protected]>
Date: Fri, 24 Nov 2023 08:27:40 +0100
Am Thu, 23 Nov 2023 08:57:41 -0800
schrieb Rolf Keitel via Tech-talk <[email protected]>:
Hello Rolf,
> here is another solution for your dutycycle which uses one calcout
> record (DUTYCYCLE) and one analog input record (CYCLERESET).
This looks much more sophisticated than the solution I had come up with
(still need more time to understand what all the fields I have not been
using up to now, like .LA and OCAL, could be useful for in other places).
Thank you for your time and effort, and the really detailed explanation.
One thing I maybe don't understand is the "TEST:" prefix in some of the
links. These are just leftovers from testing (I had to remove them to make
the example work) or is there more to it?
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: "duty cycle" records Ralph Lange via Tech-talk
"duty cycle" records Gerrit Kühn via Tech-talk
Re: "duty cycle" records Gerrit Kühn via Tech-talk
Re: "duty cycle" records Mark Rivers via Tech-talk
Re: "duty cycle" records Rolf Keitel via Tech-talk
RE: "duty cycle" records Žiga Oven via Tech-talk
Prev: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL Carsten Winkler via Tech-talk
Next: GNU Make 4.4.1 under Windows does not completely build the EPICS base 7 Carsten Winkler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: "duty cycle" records Ralph Lange via Tech-talk
Next: Re: "duty cycle" records Ralph Lange via Tech-talk
