1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: PiezosystemJena NV40/3 CLE
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: Graeme Elliner <Graeme.Elliner at fmb-oxford.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 27 Nov 2023 09:24:24 -0600
I wrote streamDevice support for the NV40/3 CLE, which resides in the ip module. There isn't a dedicated IOC for it, but there is an example configuration that can be copied to a dedicated IOC:
https://github.com/epics-modules/ip/blob/master/iocs/ipExample/iocBoot/iocIpExample/JenaNV40_3CLE.cmd
Kevin
On 11/20/23 03:14, Graeme Elliner via Tech-talk wrote:
Hi
I’m trying to ascertain if there is a PiezosystemJena IOC for the NV40/3 CLE and I’ve been struggling to find it using the search facility.
We’ve discovered that Physik Instrumente Piezo controllers are on a long and variable lead time and want to use the PSJ NV40 instead.
Best Regards,
*Graeme Elliner*
Senior Control & Electrical Engineer
FMB Oxford Limited
Tel: 01865 320311 Direct Dial
Tel: 01865 320300 Switchboard
	A close up of a sign Description automatically generated
Visit us at: _
_www.fmb-oxford.com<http://www.fmb-oxford.com/>
https://www.linkedin.com/company/fmb-oxford<https://www.linkedin.com/company/fmb-oxford>
https://www.facebook.com/FMBOxford<https://www.facebook.com/FMBOxford>
https://twitter.com/FMB_Oxford<https://twitter.com/FMB_Oxford>
*P*Before you print think about the***ENVIRONMENT*
FMB Oxford Limited is a company registered in England and Wales. Registered number: 04138193. Registered Office: Unit One, Ferry Mills, Osney Mead, Oxford, OX2 0ES, UK. A subsidiary of FMB Feinwerk- und Messtechnik GmbH.
This e-mail message may contain confidential information and is intended for the addressee only. If you are not the intended recipient, please notify the sender by return e-mail and delete this message immediately. Reproduction, dissemination or distribution of this message is prohibited unless authorised by the sender. The views expressed by the sender are not necessarily those of FMB Oxford Limited. This e-mail has passed through Microsoft's Exchange Online Protection services. FMB Oxford Limited accepts no responsibility for any viruses not revealed.
PiezosystemJena NV40/3 CLE Graeme Elliner via Tech-talk
Prev: Re: Beckhoff ADS to EPICS Torsten Bögershausen via Tech-talk
Next: Re: maxnet encoder problem Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: PiezosystemJena NV40/3 CLE Graeme Elliner via Tech-talk
Next: New releases of mrfioc2 drivers for MRF timing hardware Jerzy via Tech-talk
ANJ, 27 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
