No one has reported encoder problems with the MAXnet support, so I
suspect it might be a configuration problem.
What is the init string argument to the omsMaxNetConfig call?
https://github.com/epics-motor/motorOmsAsyn/blob/fa94d1dfb5051591783637e137ebb16166590f8e/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/MAXnet.cmd#L25
Which axis is misbehaving?
Kevin
On 11/19/23 18:21, 백호령 via Tech-talk wrote:
As I result of my search, i understand that OMS's MAXv and MAXnet can be
used as the motorOmsAsyn of the epics motor module.
For MAXv, the encoder pulse value is read correctly, but for MAXnet, the
encoder pulse value is read correctly only at the beginning and splashes
ti an odd value at the second move. Is this a problem with epics code?Or
should I thinj of it as a hardware problem and solve it?
Thank you for your help.
Baeg.
- maxnet encoder problem 백호령 via Tech-talk
Re: PiezosystemJena NV40/3 CLE Kevin Peterson via Tech-talk
support for the QuTools quDis interferometer Chitra Venkataraman via Tech-talk
<2023>
PiezosystemJena NV40/3 CLE Graeme Elliner via Tech-talk
<2023>
