As I result of my search, i understand that OMS's MAXv and MAXnet can be used as the motorOmsAsyn of the epics motor module.
For MAXv, the encoder pulse value is read correctly, but for MAXnet, the encoder pulse value is read correctly only at the beginning and splashes ti an odd value at the second move. Is this a problem with epics code?Or should I thinj of it as a hardware problem and solve it? Thank you for your help. Baeg.
ANJ, 27 Nov 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
