Subject: |
C and C++ standard required by EPICS 7 Base and modules? |
"J. Lewis Muir via Tech-talk" <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Tue, 28 Nov 2023 23:19:59 -0600 |
Hello!
What C language standard (e.g., C99) and C++ language standard
(e.g., C++11) does EPICS 7 Base require?
Also, is there a C and C++ language standard for EPICS 7 modules?
BTW, the EPICS 7 Base build system does not specify a C and C++ standard
when compiling (e.g., via a "-std=" compiler option) on most platforms,
but I think it should on all platforms. I only see that compiler option
being used in the following:
configure/os/CONFIG.Common.solaris-sparc-gnu
configure/os/CONFIG.Common.solaris-x86-gnu
configure/os/CONFIG.Common.RTEMS-uC5282
Without that option, the standard when compiling is just whatever the
compiler defaults to.
Thanks!
Lewis
- Re: C and C++ standard required by EPICS 7 Base and modules? Michael Davidsaver via Tech-talk
Re: Don't use epics-base with WSL 1 (Re: SoftIoc with Warning: Unable to clear IP_MULTICAST_ALL on Ubunto on WSL) J. Lewis Muir via Tech-talk
Re: Simulated limit switches on motorSim motor Torsten Bögershausen via Tech-talk
<2023>
2025
2026
IP230 driver Qing Ma via Tech-talk
<2023>
2025
2026
