On 11/28/23 21:19, J. Lewis Muir via Tech-talk wrote:
Hello!
What C language standard (e.g., C99) and C++ language standard
(e.g., C++11) does EPICS 7 Base require?
Currently epics-base and the bundled PVA modules should build with -std=c++98.
Also, is there a C and C++ language standard for EPICS 7 modules?
BTW, the EPICS 7 Base build system does not specify a C and C++ standard
when compiling (e.g., via a "-std=" compiler option) on most platforms,
but I think it should on all platforms. I only see that compiler option
being used in the following:
Of more practical importance than -std=... we test with older G++ and MSVC.
eg. with my PVXS modules, while I say >= c++11. In practice my compatibility
target is g++ >= 4.8 (circa RHEL7) which implemented most, but not all, of c++11.
configure/os/CONFIG.Common.solaris-sparc-gnu
configure/os/CONFIG.Common.solaris-x86-gnu
configure/os/CONFIG.Common.RTEMS-uC5282
Without that option, the standard when compiling is just whatever the
compiler defaults to.
Thanks!
Lewis
- Re: C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
- C and C++ standard required by EPICS 7 Base and modules? J. Lewis Muir via Tech-talk
Andor3 IOC detects and connects to Marana, can get frames, but frames appear noisy/corrupted Wlodek, Jakub via Tech-talk
Problem deploying Archiver Appliance Eusebio Naif Al-Soliman Fuentes via Tech-talk
<2023>
<2023>
