> :/home/usuario/archappl_install/apache-tomcat-10.1.16/lib …
> java.lang.NoClassDefFoundError: javax/servlet/ServletContextListener
Looks like you’re using Tomcat 10, which changed the API.
Classes javax/servlet have been renamed/moved to Jakarta/servlet.
Try using tomcat 9 which still has the javax/servlet classes
Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Eusebio Naif Al-Soliman Fuentes via Tech-talk <tech-talk at aps.anl.gov>
Date: Wednesday, November 29, 2023 at 10:47 AM
To: Tech Talk <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Problem deploying Archiver Appliance
I'm deploying a basic Archiver Appliance in a Virtual Machine with the
install_scripts/single_machine_install.sh
script. I have encountered the next error in the retrieval/logs/catalina.err
file:
Nov 29, 2023 4:00:30 PM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Error configuring application listener of class [org.epics.archiverappliance.config.ArchServletContextListener]
at java.base/java.lang.ClassLoader.defineClass1(Native Method)
at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1012)
at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150)
at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2352)
at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:800)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1317)
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1165)
at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:491)
at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:473)
at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:143)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4349)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4860)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:712)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:975)
at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1952)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:776)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:426)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1659)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:114)
at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:402)
at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:345)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:893)
at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:845)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1332)
at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1322)
at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145)
at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:866)
at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:240)
at org.apache.catalina.core.StandardService.startInternal(StandardService.java:433)
at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:917)
at org.apache.catalina.startup.Catalina.start(Catalina.java:795)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:347)
at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:235)
Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContextListener
at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1353)
... 55 more
Has someone encountered this problem? It also happens when I use the quickstart.sh
script. I have tried with a CentOS 7 and Debian 10 VMs and in both I have the same issue.
There is another minor problem in the log:
Nov 29, 2023 4:00:21 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent
INFO: The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/home/usuario/archappl_install/retrieval/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/etl/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/engine/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/mgmt/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/EPICS/epics-base/lib/linux-x86_64:/home/usuario/archappl_install/apache-tomcat-10.1.16/lib:/usr/lib/jvm/jdk-17-oracle-x64/lib/server:/usr/lib/jvm/jdk-17-oracle-x64/lib:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib]
However, I don't think that this is the problem which it's blocking me, but it's still interesting to know what's happening with the SSL library, because I think that the dependencies
are already installed.
Thanks in advance. Eusebio.
Saludos/Best regards
University of Granada
MSc.
Data Science and Computer Engineering
eunaif at correo.ugr.es
- Re: [EXTERNAL] Problem deploying Archiver Appliance Eusebio Naif Al-Soliman Fuentes via Tech-talk
- Problem deploying Archiver Appliance Eusebio Naif Al-Soliman Fuentes via Tech-talk
<2023>
<2023>
ANJ, 29 Nov 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
