Hello Kay.
I've tried with Apache Tomcat 9.0.83 and now the error doesn't appear in the log. However, I'm still getting the error 404 when I'm trying to access the web page. In the browser, it appears this:
HTTP Status 404 – Not found
Type Status Report
Description The origin server did not find a current representation for the target resource or is not willing to disclose that one exists.
Apache Tomcat/9.0.83
I'm going through multiple log files, but I haven't found anything useful so far. Any idea about which file I should be looking at?
Thanks, Eusebio.
Saludos/Best regards
University of Granada
Eusebio Naif Al-Soliman Fuentes MSc. Data Science and Computer Engineering
eunaif at correo.ugr.es
El 2023-11-29 16:52, Kasemir, Kay escribió:
:/home/usuario/archappl_install/apache-tomcat-10.1.16/lib … java.lang.NoClassDefFoundError: javax/servlet/ServletContextListener
Looks like you’re using Tomcat 10, which changed the API. Classes javax/servlet have been renamed/moved to Jakarta/servlet. Try using tomcat 9 which still has the javax/servlet classes
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Eusebio Naif Al-Soliman Fuentes via Tech-talk <tech-talk at aps.anl.gov> Date: Wednesday, November 29, 2023 at 10:47 AM To: Tech Talk <tech-talk at aps.anl.gov> Subject: [EXTERNAL] Problem deploying Archiver Appliance Hello everybody.
I'm deploying a basic Archiver Appliance in a Virtual Machine with the install_scripts/single_machine_install.sh script. I have encountered the next error in the retrieval/logs/catalina.err file:
Nov 29, 2023 4:00:30 PM org.apache.catalina.core.StandardContext listenerStart SEVERE: Error configuring application listener of class [org.epics.archiverappliance.config.ArchServletContextListener] java.lang.NoClassDefFoundError: javax/servlet/ServletContextListener at java.base/java.lang.ClassLoader.defineClass1(Native Method) at java.base/java.lang.ClassLoader.defineClass(ClassLoader.java:1012) at java.base/java.security.SecureClassLoader.defineClass(SecureClassLoader.java:150) at org.apache.catalina.loader.WebappClassLoaderBase.findClassInternal(WebappClassLoaderBase.java:2352) at org.apache.catalina.loader.WebappClassLoaderBase.findClass(WebappClassLoaderBase.java:800) at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1317) at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1165) at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:491) at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:473) at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:143) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4349) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4860) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:683) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:658) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:712) at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:975) at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1952) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:123) at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:776) at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:426) at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1659) at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309) at org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:114) at org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:402) at org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:345) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:893) at org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:845) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1332) at org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1322) at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264) at org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75) at java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:145) at org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:866) at org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:240) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.StandardService.startInternal(StandardService.java:433) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:917) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:171) at org.apache.catalina.startup.Catalina.start(Catalina.java:795) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:568) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:347) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:568) at org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:235) Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContextListener at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1353) at org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1165) ... 55 more
Has someone encountered this problem? It also happens when I use the quickstart.sh script. I have tried with a CentOS 7 and Debian 10 VMs and in both I have the same issue.
There is another minor problem in the log:
Nov 29, 2023 4:00:21 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent INFO: The Apache Tomcat Native library which allows using OpenSSL was not found on the java.library.path: [/home/usuario/archappl_install/retrieval/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/etl/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/engine/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/archappl_install/mgmt/webapps/mgmt/WEB-INF/lib/native/linux-x86_64:/home/usuario/EPICS/epics-base/lib/linux-x86_64:/home/usuario/archappl_install/apache-tomcat-10.1.16/lib:/usr/lib/jvm/jdk-17-oracle-x64/lib/server:/usr/lib/jvm/jdk-17-oracle-x64/lib:/usr/java/packages/lib:/usr/lib64:/lib64:/lib:/usr/lib] However, I don't think that this is the problem which it's blocking me, but it's still interesting to know what's happening with the SSL library, because I think that the dependencies are already installed.
Thanks in advance. Eusebio. --
- Re: Problem deploying Archiver Appliance Wang, Lin via Tech-talk
- Problem deploying Archiver Appliance Eusebio Naif Al-Soliman Fuentes via Tech-talk
- Re: [EXTERNAL] Problem deploying Archiver Appliance Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Problem deploying Archiver Appliance Shankar, Murali via Tech-talk
<2023>
2025
<2023>
2025
ANJ, 29 Nov 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
