1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: camonitor vs caput
From: Gerrit Kühn via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 5 Dec 2023 08:20:05 +0100
Hello,
I have a device continuously sending data that I parse via StreamDevice
into the following records:
record (ai, "$(CHAN)_CT_03") {
  field (DESC, "PM count greater 0.3µm")
  field (DTYP, "stream")
  field (INP, "@particulatematter.proto getCount($(U),$(CHAN)) $(CBPCT)")
  field (SCAN, "I/O Intr")
record (ai, "$(CHAN)_CT_05") {
  field (DESC, "PM count greater 0.5µm")
record (ai, "$(CHAN)_CT_10") {
  field (DESC, "PM count greater 1.0µm")
record (ai, "$(CHAN)_CT_25") {
  field (DESC, "PM count greater 2.5µm")
record (ai, "$(CHAN)_CT_50") {
  field (DESC, "PM count greater 5.0µm")
record (ai, "$(CHAN)_CT_100") {
  field (DESC, "PM count greater 10.0µm")
In the protocol, the first record is parsed directly, the others are
populated using record redirection:
in
"greater03um=%i\tgreater05um=%(\$2_CT_05)i\tgreater10um=%(\$2_CT_10)i\tgreater25um=%(\$2_CT_25)i\tgreater50um=%(\$2_CT_50)i\tgreater100um=%(\$2_CT_100)i";
This all works fine except for one thing:
Sometimes I need to reset these channels, e.g., using caput on the
commandline. This works as expected for all channels except for the first
one that is using I/O Intr scanning. For this, caput is able to change the
value, a following caget reports the new value. However, camonitor does
not recognise the change. I do get the new value when restarting
camonitor, though. This also leads to the new value not being recognised by
the archiver appliance.
As this works fine with all other records, it looks to me like the
scanning field (I/O Intr), maybe in combination with StreamDevice, is
causing my trouble here. Is this expected behaviour? How can I achieve
that caput changes are recognised by camonitor on I/O Intr records?
cu
  Gerrit
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: camonitor vs caput Gerrit Kühn via Tech-talk
Re: camonitor vs caput Johnson, Andrew N. via Tech-talk
Prev: Re: mbbo with 32 choices Kasemir, Kay via Tech-talk
Next: Re: camonitor vs caput Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: EPICS Collaboration Meeting 2024 – save the date 조우성(제어전원장치팀) via Tech-talk
