1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: [EXTERNAL] Can phoebus tool tip show a PV's server?
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Paul Sichta <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 11 Dec 2023 17:56:55 +0000
From the context menu, you can copy the PV name and then use that to run “cainfo” from the command line.
Note that you might then get the address of a CA gateway, not the IOC behind it.
From: Tech-talk <[email protected]> on behalf of Paul Sichta via Tech-talk <[email protected]>
Date: Monday, December 11, 2023 at 12:41 PM
To: [email protected] <[email protected]>
Subject: [EXTERNAL] Can phoebus tool tip show a PV's server?
When hovering the mouse over a display's widget the $(pv_name) and $(pv_value) are often shown.  Is there a property that can show which IOC is serving that PV?
-ps
Can phoebus tool tip show a PV's server? Paul Sichta via Tech-talk
Prev: Can phoebus tool tip show a PV's server? Paul Sichta via Tech-talk
Next: Re: Can phoebus tool tip show a PV's server? Tynan Ford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
