If your site uses Recsync and Channel Finder you can also use the right click Context Menu and select "Channel Info". This will show you the IOC name, host name, and IOC IP address and port.
When hovering the mouse over a display's widget the $(pv_name) and $(pv_value) are often shown. Is there a property that can show which IOC is serving that PV?
Regards, -ps
- Can phoebus tool tip show a PV's server? Paul Sichta via Tech-talk
Re: [EXTERNAL] Can phoebus tool tip show a PV's server? Kasemir, Kay via Tech-talk
Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
<2023>
2025
dbGetLink documentation update suggestion Ivo Hanak via Tech-talk
<2023>
2025
ANJ, 12 Dec 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
