Dear Madam/Sir, I am writing here because I would like to suggest an update to documentation as the behavior I observed seems to match the code. It is just not expected (at least it was so for me). Feel free to reject the suggestion if I am misinterpreting anything. EPICS 7.0.6.1 If conditions are right, dbGetLink() retrieving DBR_STRING from a DBF_ENUM CA link pointing at a PV hosted by a remote IOC may return -1 even though dbIsLinkConnected() says the link is connected. This occurs when dbGetLink() is used with the link for the first time after IOC startup. I assume this is a result of a delayed string monitoring request (CA_MONITOR_STRING) in dbCaGetLink() (dbCa.c). A retry slightly later works as expected. Using google I found following documents: * https://controlssoftware.sns.ornl.gov/training/2019_USPAS/Presentations/02b%20AppDevGuide_3_15_6.pdf Yet, none of them seems to mention this behavior next to the description of dbGetField(). Also, dbCa.h does not describe it. And, I was not able to find description of dbGetLink() at https://epics-controls.org/. Yet, I admit I gave up after I got lost there. Still, unless my explananation is incorrect, would it possible to
add description of this behavior to documentation of dbGetLink() unless
it is already there, please? Something like this: While reading a string (dbrType DBR_STRING) from a CA link of type DBF_ENUM, this routine may return -1 even though it is connected (use
dbIsLinkConnected to check). This happens when the routing is used for the first time with this link especially if the link points at PV hosted by a remote IOC. This is a result of CA routines which request the string representation on demand only. Retrying this routine a little bit later may provide expected result (i.e. the string). Thank you. Sincerely, Ivo Hanak
ANJ, 12 Dec 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
