1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: is there an EPICS module to makePvToArchiveFromDbInfo() ?
From: NADOT Victor via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 15 Dec 2023 10:28:47 +0000
Thanks all for your answers.
dbli is exactly what I needed, thanks ! (I keep in my mind the 2 other
solutions ;) )
Victor Nadot
Ingénieur Systèmes Electroniques Embarqués
CEA Saclay - DRF / IRFU / DIS / LDISC
Bâtiment 472 - pièce 77
+ 33 (0)1 69 08 41 88
Le jeudi 14 décembre 2023 à 09:10 -0800, Tynan Ford a écrit :
> Hi Victor,
> In case you are using the archiver appliance and channel
> finder/recsync, you can accomplish this via the channel finder AA
> processor -
>  https://github.com/ChannelFinder/ChannelFinderService/blob/master/sr
> c/main/resources/application.properties#L96
> Best,
> Tynan
> On Thu, Dec 14, 2023 at 7:24 AM Pearson, Matthew via Tech-talk
> <[email protected]> wrote:
> > Hi Victor,
> > If you use a recent version of base, you can list tags on the IOC
> > shell and write them to a file:
> > epics> dbli *archive*
> > ST99:Det:IOC_SADet3:Status info(archive, "Monitor, 00:00:01, VAL")
> > ST99:Det:IOC_SADet3:StatCtrl info(archive, "Monitor, 00:00:01,
> > VAL")
> > ST99:Det:IOC_SIDet3:STATUS info(archive, "Monitor, 00:00:01, VAL")
> > ST99:Det:IOC_SIDet3:STATCTRL info(archive, "Monitor, 00:00:01,
> > VAL")
> > epics>
> > epics> dbli *archive* > /tmp/archive_list.txt
> > cat /tmp/archive_list.txt
> > VAL")
> > VAL")
> > Then you can parse that list and generate an archive configuration.
> > Or, modify an archiver to be able to read that format.
> > We use a Python script to parse the database files, but if we were
> > starting today I'd probably use the above method as the first step
> > in extracting the info tags.
> > Cheers,
> > Matt
> > -----Original Message-----
> > From: Tech-talk <[email protected]> On Behalf Of Simon
> > Rose via Tech-talk
> > Sent: Thursday, December 14, 2023 5:23 AM
> > To: NADOT Victor <[email protected]>; [email protected]
> > Subject: [EXTERNAL] Re: is there an EPICS module to
> > Hi Victor -
> > There is one that we have used at ESS that might serve your
> > purpose:
> > https://urldefense.us/v2/url?u=https-3A__gitlab.esss.lu.se_icshwi_iocmetadata&d=DwIGaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=aEDRFW1J1RKf3L4Vy5iLgaY2FJpZ2TV1XDtc_tKxW00&m=vNISIrtmTSvaQHTNeWDl1p15L43in4-yA1-44ChtrvumzGayCjG4ekJITH08uJbN&s=CH3zpoO636P0uNZGzJnegnwLIRfFkNbkML82l2Cap0E&e=
> > Note that it uses EPICS 7 NT types. There is pretty good
> > documentation in the README file in the repository.
> > Cheers,
> > Simon
> > On 2023-12-14, 10:29, "Tech-talk on behalf of NADOT Victor via
> > Tech-talk" <[email protected]
> > <mailto:[email protected]> on behalf of
> > [email protected] <mailto:[email protected]>> wrote:
> > Hi all,
> > is there an EPICS module to, in the same way as
> > `makeAutosaveFileFromDbInfo()` works, generate (at IOC boot, so
> > macro are resolved) a file with a list of PV names to archive from
> > the information provided in the record `info()` field ?
> > ```epics
> > record(ai, "MyPv") {
> > info(archive, "YES")
> > This would be a nice tool to then copy/past all the pv list files
> > to archive in the archiver.
> > Thanks for the answer,
> > Cheers,
> > Victor Nadot
> > Ingénieur Systèmes Electroniques Embarqués CEA Saclay - DRF / IRFU
> > / DIS / LDISC Bâtiment 472 - pièce 120
> > + 33 (0)6 45 03 12 54
is there an EPICS module to makePvToArchiveFromDbInfo() ? NADOT Victor via Tech-talk
Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? Simon Rose via Tech-talk
RE: is there an EPICS module to makePvToArchiveFromDbInfo() ? Pearson, Matthew via Tech-talk
Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? Tynan Ford via Tech-talk
Prev: PVXS on RTEMS (Re: PVXS release 1.3.0) Michael Davidsaver via Tech-talk
Next: Re: [EXTERNAL] EPICS vs. EPICS Base consistency on website? J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: is there an EPICS module to makePvToArchiveFromDbInfo() ? Tynan Ford via Tech-talk
Next: sscan mda format convert 顾月良 via Tech-talk
