1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: quadEM-R7-0 ParamValNotDefined
To: [email protected]
Date: Tue, 19 Dec 2023 14:34:44 -0600
Hello,
Sorry I am living in the past. I am trying to install the old version
quadEM-R7-0 to match the  EPICS_base version (3.14.12.8) and Asyn
version in use.
I installed everything without vxWorks, with the intention to run the
IOC on a PC. Currently working on RHEL linux-arm inside VMware Fusion.
The TetrAMM instrument is new, but I guess the error message is not
about hardware but EPICS software. The printout of starting IOC is as
follows:
[rh@localhost iocTetrAMM]$ ../../bin/linux-arm/quadEMTestApp st.cmd
errlogInit(5000)
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocTetrAMM")
epicsEnvSet("TOP","/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0")
epicsEnvSet("SUPPORT","/epicsioc/used/epics/synApps_5_8_3_14_8")
epicsEnvSet("AREA_DETECTOR","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5")
epicsEnvSet("EPICS_BASE","/epicsioc/used/epics/base-3.14.12.8")
epicsEnvSet("ASYN","/epicsioc/used/epics/synApps_5_8_3_14_8/asyn-4-36")
epicsEnvSet("ADSUPPORT","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADSupport")
epicsEnvSet("ADCORE","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADCore")
epicsEnvSet("AUTOSAVE","/epicsioc/used/epics/synApps_5_8_3_14_8/autosave-5-10")
epicsEnvSet("BUSY","/epicsioc/used/epics/synApps_5_8_3_14_8/busy-1-7-2")
epicsEnvSet("CALC","/epicsioc/used/epics/synApps_5_8_3_14_8/calc-3-7-3")
epicsEnvSet("SNCSEQ","/epicsioc/used/epics/synApps_5_8_3_14_8/seq-2-2-7")
epicsEnvSet("SSCAN","/epicsioc/used/epics/synApps_5_8_3_14_8/sscan-2-11-3")
epicsEnvSet("DEVIOCSTATS","/epicsioc/used/epics/synApps_5_8_3_14_8/iocStats-3-1-16")
epicsEnvSet("IPAC","/epicsioc/used/epics/synApps_5_8_3_14_8/ipac-2-15")
epicsEnvSet("IPUNIDIG","/epicsioc/used/epics/synApps_5_8_3_14_8/ipUnidig-2-10")
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in this build
epicsEnvSet("QUADEM","/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0")
dbLoadDatabase("/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/dbd/quadEMTestApp.dbd")
quadEMTestApp_registerRecordDeviceDriver(pdbbase)
# The search path for database files
# Note: the separator between the path entries needs to be changed to
a semicolon (;) on Windows
epicsEnvSet("EPICS_DB_INCLUDE_PATH",
"/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADCore/db:/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/db")
< /epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/iocBoot/iocTetrAMM/TetrAMM.cmd
epicsEnvSet("PREFIX",    "quadEMTest:")
epicsEnvSet("RECORD",    "TetrAMM:")
epicsEnvSet("PORT",      "TetrAMM")
epicsEnvSet("TEMPLATE",  "TetrAMM")
epicsEnvSet("QSIZE",     "20")
epicsEnvSet("RING_SIZE", "10000")
epicsEnvSet("TSPOINTS",  "2048")
#epicsEnvSet("IP",        "164.54.160.165:10001")
epicsEnvSet("IP",        "10.1.17.35:10001")
#drvAsynIPPortConfigure("portName","hostInfo",priority,noAutoConnect,
#                        noProcessEos)
drvAsynIPPortConfigure("IP_TetrAMM", "10.1.17.35:10001", 0, 0, 0)
asynOctetSetInputEos("IP_TetrAMM",  0, "\r\n")
asynOctetSetOutputEos("IP_TetrAMM", 0, "\r")
# Set both TRACE_IO_ESCAPE (for ASCII command/response) and
TRACE_IO_HEX (for binary data)
asynSetTraceIOMask("IP_TetrAMM", 0, 6)
#asynSetTraceFile("IP_$(PORT)",   0, "AHxxx.out")
#asynSetTraceMask("IP_$(PORT)",   0,  9)
asynSetTraceIOTruncateSize("IP_TetrAMM", 0, 4000)
# Load asynRecord record
dbLoadRecords("/epicsioc/used/epics/synApps_5_8_3_14_8/asyn-4-36/db/asynRecord.db",
"P=quadEMTest:, R=asyn1,PORT=IP_TetrAMM,ADDR=0,OMAX=256,IMAX=256")
drvTetrAMMConfigure("TetrAMM", "IP_TetrAMM", 10000)
dbLoadRecords("/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/db/TetrAMM.template",
"P=quadEMTest:, R=TetrAMM:, PORT=TetrAMM")
< /epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/iocBoot/commonPlugins.cmd
epicsEnvSet("T1",  "Current1")
epicsEnvSet("T2",  "Current2")
epicsEnvSet("T3",  "Current3")
epicsEnvSet("T4",  "Current4")
epicsEnvSet("T5",  "SumX")
epicsEnvSet("T6",  "SumY")
epicsEnvSet("T7",  "SumAll")
epicsEnvSet("T8",  "DiffX")
epicsEnvSet("T9",  "DiffY")
epicsEnvSet("T10", "PosX")
epicsEnvSet("T11", "PosY")
# Create 11 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "TetrAMM", 0, 0, 0)
terminate called after throwing an instance of 'ParamValNotDefined'
  what():  paramVal::getInteger value not defined
Aborted (core dumped)
Thank you for your attention,
Rong
RE: quadEM-R7-0 ParamValNotDefined Mark Rivers via Tech-talk
Prev: RE: sscan mda format convert Mark Rivers via Tech-talk
Next: RE: quadEM-R7-0 ParamValNotDefined Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Agilent analytics devices like GCs (gas chromatography) integration into EPICS framework? Heinz Junkes via Tech-talk
