1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: quadEM-R7-0 ParamValNotDefined
To: Rong Huang <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 19 Dec 2023 22:10:19 +0000
Hi Rong,
You appear to be running asyn R4-36.
You are getting this error:
NDStatsConfigure("STATS1", 20, 0, "TetrAMM", 0, 0, 0) terminate called after throwing an instance of 'ParamValNotDefined'
  what():  paramVal::getInteger value not defined Aborted (core dumped)
I do not understand that.  The only place where paramVal::getInteger should be called is in this line in asynPortDriver R4-36:
https://github.com/epics-modules/asyn/blob/89c2b93d14cdb7fe48d490785cd7780c1b997277/asyn/asynPortDriver/asynPortDriver.cpp#L288
Note that paramVal::getInteger is called in a try/catch block, and exception ParamValNotDefined is explicitly caught.  So it should simply return asynParamUndefined to the function that called paramList::GetInteger, which is normally asynPortDriver::getIntegerParam().
Your error message says that the crash generated a core dump.  I think you need to run gdb on that core file and send the output of the gdb “backtrace” command.
Alternatively you can run the IOC again under gdb as follows:
gdb ../../bin/linux-arm/quadEMTestApp
run st.cmd
(when it crashes type this command)
backtrace
That will show the call stack when it crashed, and we may be able to figure out why it is happening.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Rong Huang via Tech-talk
Sent: Tuesday, December 19, 2023 2:35 PM
To: [email protected]
Subject: quadEM-R7-0 ParamValNotDefined
Hello,
Sorry I am living in the past. I am trying to install the old version
quadEM-R7-0 to match the  EPICS_base version (3.14.12.8) and Asyn version in use.
I installed everything without vxWorks, with the intention to run the IOC on a PC. Currently working on RHEL linux-arm inside VMware Fusion.
The TetrAMM instrument is new, but I guess the error message is not about hardware but EPICS software. The printout of starting IOC is as
follows:
[rh@localhost iocTetrAMM]$ ../../bin/linux-arm/quadEMTestApp st.cmd
errlogInit(5000)
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocTetrAMM")
epicsEnvSet("TOP","/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0")
epicsEnvSet("SUPPORT","/epicsioc/used/epics/synApps_5_8_3_14_8")
epicsEnvSet("AREA_DETECTOR","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5")
epicsEnvSet("EPICS_BASE","/epicsioc/used/epics/base-3.14.12.8")
epicsEnvSet("ASYN","/epicsioc/used/epics/synApps_5_8_3_14_8/asyn-4-36")
epicsEnvSet("ADSUPPORT","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADSupport")
epicsEnvSet("ADCORE","/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADCore")
epicsEnvSet("AUTOSAVE","/epicsioc/used/epics/synApps_5_8_3_14_8/autosave-5-10")
epicsEnvSet("BUSY","/epicsioc/used/epics/synApps_5_8_3_14_8/busy-1-7-2")
epicsEnvSet("CALC","/epicsioc/used/epics/synApps_5_8_3_14_8/calc-3-7-3")
epicsEnvSet("SNCSEQ","/epicsioc/used/epics/synApps_5_8_3_14_8/seq-2-2-7")
epicsEnvSet("SSCAN","/epicsioc/used/epics/synApps_5_8_3_14_8/sscan-2-11-3")
epicsEnvSet("DEVIOCSTATS","/epicsioc/used/epics/synApps_5_8_3_14_8/iocStats-3-1-16")
epicsEnvSet("IPAC","/epicsioc/used/epics/synApps_5_8_3_14_8/ipac-2-15")
epicsEnvSet("IPUNIDIG","/epicsioc/used/epics/synApps_5_8_3_14_8/ipUnidig-2-10")
# Tell EPICS all about the record types, device-support modules, drivers, # etc. in this build
epicsEnvSet("QUADEM","/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0")
dbLoadDatabase("/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/dbd/quadEMTestApp.dbd")
quadEMTestApp_registerRecordDeviceDriver(pdbbase)
# The search path for database files
# Note: the separator between the path entries needs to be changed to a semicolon (;) on Windows epicsEnvSet("EPICS_DB_INCLUDE_PATH",
"/epicsioc/used/epics/synApps_5_8_3_14_8/areaDetector-R2-5/ADCore/db:/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/db")
< /epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/iocBoot/iocTetrAMM/TetrAMM.cmd
epicsEnvSet("PREFIX",    "quadEMTest:")
epicsEnvSet("RECORD",    "TetrAMM:")
epicsEnvSet("PORT",      "TetrAMM")
epicsEnvSet("TEMPLATE",  "TetrAMM")
epicsEnvSet("QSIZE",     "20")
epicsEnvSet("RING_SIZE", "10000")
epicsEnvSet("TSPOINTS",  "2048")
#epicsEnvSet("IP",        "164.54.160.165:10001")
epicsEnvSet("IP",        "10.1.17.35:10001")
#drvAsynIPPortConfigure("portName","hostInfo",priority,noAutoConnect,
#                        noProcessEos)
drvAsynIPPortConfigure("IP_TetrAMM", "10.1.17.35:10001", 0, 0, 0) asynOctetSetInputEos("IP_TetrAMM",  0, "\r\n") asynOctetSetOutputEos("IP_TetrAMM", 0, "\r") # Set both TRACE_IO_ESCAPE (for ASCII command/response) and TRACE_IO_HEX (for binary data) asynSetTraceIOMask("IP_TetrAMM", 0, 6)
#asynSetTraceFile("IP_$(PORT)",   0, "AHxxx.out")
#asynSetTraceMask("IP_$(PORT)",   0,  9)
asynSetTraceIOTruncateSize("IP_TetrAMM", 0, 4000) # Load asynRecord record dbLoadRecords("/epicsioc/used/epics/synApps_5_8_3_14_8/asyn-4-36/db/asynRecord.db",
"P=quadEMTest:, R=asyn1,PORT=IP_TetrAMM,ADDR=0,OMAX=256,IMAX=256")
drvTetrAMMConfigure("TetrAMM", "IP_TetrAMM", 10000) dbLoadRecords("/epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/db/TetrAMM.template",
"P=quadEMTest:, R=TetrAMM:, PORT=TetrAMM") < /epicsioc/used/epics/synApps_5_8_3_14_8/quadEM-R7-0/iocBoot/commonPlugins.cmd
epicsEnvSet("T1",  "Current1")
epicsEnvSet("T2",  "Current2")
epicsEnvSet("T3",  "Current3")
epicsEnvSet("T4",  "Current4")
epicsEnvSet("T5",  "SumX")
epicsEnvSet("T6",  "SumY")
epicsEnvSet("T7",  "SumAll")
epicsEnvSet("T8",  "DiffX")
epicsEnvSet("T9",  "DiffY")
epicsEnvSet("T10", "PosX")
epicsEnvSet("T11", "PosY")
# Create 11 statistics plugins
Thank you for your attention,
Rong
Re: quadEM-R7-0 ParamValNotDefined Rong Huang via Tech-talk
Prev: quadEM-R7-0 ParamValNotDefined Rong Huang via Tech-talk
Next: Re: quadEM-R7-0 ParamValNotDefined Rong Huang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
