1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: asyn ioctestIPServer prints many accept errors after IOC exit?
To: "J. Lewis Muir" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Wed, 20 Dec 2023 22:52:02 +0000
Lewis,
I have replied to your issue on Github:
- You had an error when you started the IOC because envPaths could not be found.  This is probably because you did not change ARCH in ioctestIPServer/Makefile to match your EPICS_HOST_ARCH, so it did not create the envPaths file.
- When I run the IOC on linux-x86_64 it exits cleanly, I do not see any error messages.
- When I run the IOC on windows-x64-static I see 2 error messages and then it exits cleanly.
The problem may be specific to Darwin.  You are one of relatively few people who run EPICS on Darwin, so you may need to debug this yourself and submit a Pull Request to fix it.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of J. Lewis Muir via Tech-talk
Sent: Wednesday, December 20, 2023 4:01 PM
To: EPICS Tech-Talk <[email protected]>
Subject: asyn ioctestIPServer prints many accept errors after IOC exit?
Hello!
After exiting the ioctestIPServer of asyn 4-44-2, thousands of error messages get printed to the standard error stream.
I created an issue on GitHub for this a few days ago:
  https://github.com/epics-modules/asyn/issues/199
Since I didn't hear anything on that issue, I'm posting here.
The specific behavior is that after exiting ioctestIPServer, a "Software caused connection abort" error message gets printed to the standard error stream
2023/12/15 16:09:01.998 drvAsynIPServerPort: accept error on  ª  : fd=5, Software caused connection abort
followed by tens of "Socket operation on non-socket" error messages
2023/12/15 16:09:01.998 drvAsynIPServerPort: accept error on (null): fd=0, Socket operation on non-socket
followed by another "Software caused connection abort" error message, but for a different file descriptor (maybe the other server?)
2023/12/15 16:09:01.999 drvAsynIPServerPort: accept error on      : fd=4, Software caused connection abort
followed by thousands more of the "Socket operation on non-socket" error messages
2023/12/15 16:09:01.999 drvAsynIPServerPort: accept error on (null): fd=0, Socket operation on non-socket
Here's an example terminal session (using EPICS 7.0.7; the same problem also exists when using EPICS 7.0.8):
$ cd iocBoot/ioctestIPServer
$ ../../bin/darwin-aarch64/testIPServer st.cmd < envPaths Can't open envPaths: No such file or directory
dbLoadDatabase("../../dbd/testIPServer.dbd")
testIPServer_registerRecordDeviceDriver(pdbbase)
#The following command starts a server on port 5001
drvAsynIPServerPortConfigure("P5001","localhost:5001",2,0,0,0)
serverAddr: 0.0.0.0:5001
serverPort: 5001
drvAsynIPServerPortConfigure("P5002","localhost:5002",1,0,0,0)
serverAddr: 0.0.0.0:5002
serverPort: 5002
#asynSetTraceFile("P5001",-1,"")
asynSetTraceIOMask("P5001",-1,0x2)
#asynSetTraceMask("P5001",-1,0xff)
dbLoadRecords("../../db/testIPServer.db", "P=testIPServer:")
iocInit()
Starting iocInit
## EPICS R7.0.7
## Rev. 2023-11-28T21:51-0600
## Rev. Date build date/time:
ipEchoServer("P5001")
seq("ipSNCServer", "P=testIPServer:, PORT=P5002") sevr=info Sequencer release 2.2.9, compiled Fri Dec 15 15:36:22 2023 sevr=info Spawning sequencer program "ipSNCServer", thread 0x600003684000: "ipSNCServer"
sevr=info ipSNCServer[0]: all channels connected & received 1st monitor
epics> exit
2023/12/15 16:09:01.998 drvAsynIPServerPort: accept error on (null): fd=0, Socket operation on non-socket [previous line repeated tens of times sans timestamp differences]
2023/12/15 16:09:01.999 drvAsynIPServerPort: accept error on (null): fd=0, Socket operation on non-socket [previous line repeated thousands of times sans timestamp differences]
Platform:
* Apple Silicon (EPICS_HOST_ARCH=darwin-aarch64)
* macOS Sonoma 14.1.1
* EPICS 7.0.8
* Asyn 4-44-2
Thanks!
Lewis
RE: asyn ioctestIPServer prints many accept errors after IOC exit? Freddie Akeroyd - STFC UKRI via Tech-talk
Re: asyn ioctestIPServer prints many accept errors after IOC exit? J. Lewis Muir via Tech-talk
Prev: asyn ioctestIPServer prints many accept errors after IOC exit? J. Lewis Muir via Tech-talk
Next: RE: asyn ioctestIPServer prints many accept errors after IOC exit? Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
