1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: asyn ioctestIPServer prints many accept errors after IOC exit?
From: Freddie Akeroyd - STFC UKRI via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, "J. Lewis Muir" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 20 Dec 2023 23:16:20 +0000
I wonder if this is a cleanup race condition - drvAsynIPServerPort calls  epicsAtExit(ttyCleanup, tty)  and I think the accept loop thread keeps trying to use the same tty structure after it has been deallocated leading to unpredictable behaviour
Freddie
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of Mark Rivers
> via Tech-talk
> Sent: 20 December 2023 22:52
> To: J. Lewis Muir <[email protected]>; EPICS Tech-Talk <tech-
> [email protected]>
> Lewis,
> I have replied to your issue on Github:
> - You had an error when you started the IOC because envPaths could not be
> found.  This is probably because you did not change ARCH in
> ioctestIPServer/Makefile to match your EPICS_HOST_ARCH, so it did not
> create the envPaths file.
> - When I run the IOC on linux-x86_64 it exits cleanly, I do not see any error
> messages.
> - When I run the IOC on windows-x64-static I see 2 error messages and then it
> exits cleanly.
> The problem may be specific to Darwin.  You are one of relatively few people
> who run EPICS on Darwin, so you may need to debug this yourself and submit
> a Pull Request to fix it.
> Mark
> From: Tech-talk <[email protected]> On Behalf Of J. Lewis Muir
> via Tech-talk
> Sent: Wednesday, December 20, 2023 4:01 PM
> To: EPICS Tech-Talk <[email protected]>
> Subject: asyn ioctestIPServer prints many accept errors after IOC exit?
> Hello!
> After exiting the ioctestIPServer of asyn 4-44-2, thousands of error messages
> get printed to the standard error stream.
> I created an issue on GitHub for this a few days ago:
>   https://github.com/epics-modules/asyn/issues/199
> Since I didn't hear anything on that issue, I'm posting here.
> The specific behavior is that after exiting ioctestIPServer, a "Software caused
> connection abort" error message gets printed to the standard error stream
> 2023/12/15 16:09:01.998 drvAsynIPServerPort: accept error on  ª  : fd=5,
> Software caused connection abort
> followed by tens of "Socket operation on non-socket" error messages
> 2023/12/15 16:09:01.998 drvAsynIPServerPort: accept error on (null): fd=0,
> followed by another "Software caused connection abort" error message, but
> for a different file descriptor (maybe the other server?)
> 2023/12/15 16:09:01.999 drvAsynIPServerPort: accept error on      : fd=4,
> followed by thousands more of the "Socket operation on non-socket" error
> messages
> 2023/12/15 16:09:01.999 drvAsynIPServerPort: accept error on (null): fd=0,
> Here's an example terminal session (using EPICS 7.0.7; the same problem also
> exists when using EPICS 7.0.8):
> $ cd iocBoot/ioctestIPServer
> $ ../../bin/darwin-aarch64/testIPServer st.cmd < envPaths Can't open
> envPaths: No such file or directory
> dbLoadDatabase("../../dbd/testIPServer.dbd")
> testIPServer_registerRecordDeviceDriver(pdbbase)
> #The following command starts a server on port 5001
> drvAsynIPServerPortConfigure("P5001","localhost:5001",2,0,0,0)
> serverAddr: 0.0.0.0:5001
> serverPort: 5001
> drvAsynIPServerPortConfigure("P5002","localhost:5002",1,0,0,0)
> serverAddr: 0.0.0.0:5002
> serverPort: 5002
> #asynSetTraceFile("P5001",-1,"")
> asynSetTraceIOMask("P5001",-1,0x2)
> #asynSetTraceMask("P5001",-1,0xff)
> dbLoadRecords("../../db/testIPServer.db", "P=testIPServer:")
> iocInit()
> Starting iocInit
> ## EPICS R7.0.7
> ## Rev. 2023-11-28T21:51-0600
> ## Rev. Date build date/time:
> iocRun: All initialization complete
> ipEchoServer("P5001")
> seq("ipSNCServer", "P=testIPServer:, PORT=P5002") sevr=info Sequencer
> release 2.2.9, compiled Fri Dec 15 15:36:22 2023 sevr=info Spawning
> sequencer program "ipSNCServer", thread 0x600003684000: "ipSNCServer"
> sevr=info ipSNCServer[0]: all channels connected & received 1st monitor
> epics> exit
> Socket operation on non-socket [previous line repeated tens of times sans
> timestamp differences]
> Socket operation on non-socket [previous line repeated thousands of times
> sans timestamp differences]
> Platform:
> * Apple Silicon (EPICS_HOST_ARCH=darwin-aarch64)
> * macOS Sonoma 14.1.1
> * EPICS 7.0.8
> * Asyn 4-44-2
> Thanks!
> Lewis
asyn ioctestIPServer prints many accept errors after IOC exit? J. Lewis Muir via Tech-talk
RE: asyn ioctestIPServer prints many accept errors after IOC exit? Mark Rivers via Tech-talk
Prev: RE: asyn ioctestIPServer prints many accept errors after IOC exit? Mark Rivers via Tech-talk
Next: Re: asyn ioctestIPServer prints many accept errors after IOC exit? J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
