Hi SeokHo, If the default configuration doesn't work, I guess that you should get and set up the Cross Compiler tools or toolchain to be compatible with your "embedded Linux." Then, you should build your own OS configuration file to use your own environment. Here are very old examples that may give hints to you. Best, Han On Thu, Dec 28, 2023 at 6:03 AM 문석호 via Tech-talk <tech-talk at aps.anl.gov> wrote:
-- Jeong Han Lee, Dr.rer.nat. Staff Scientist and Engineer Cell: +1 510 384 3868
| ANJ, 11 Sep 2024 |
· Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
