1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: LabCA for MATLAB Installation error
From: Michael Davidsaver via Tech-talk <[email protected]>
Cc: Giovanni Franzini <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 2 Jan 2024 17:28:42 -0800
On 1/2/24 08:28, Mark Rivers via Tech-talk wrote:
Hi Bo,
The fatal error you are getting is because gitstring.c does not exist.  But I think that is due to a non-fatal error earlier in the output:
perl -MFile::Compare -e 'exit( compare(@ARGV[0],@ARGV[1]) )'
gitstring.c.new gitstring.c || (perl -CSD -MExtUtils::Command -e rm_f
gitstring.c; perl -e 'rename("gitstring.c.new","gitstring.c")')
') was unexpected at this time.
Isn't "... was unexpected at this time" a cmd shell error?
I guess this Makefile assumes SHELL=/bin/sh ?
So I think it is trying to rename gitstring.c.new to gitstring.c and that is failing.  I think a perl expert is needed to help here?
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of boj via Tech-talk
Sent: Tuesday, January 2, 2024 9:03 AM
To: [email protected]
Dear all
I am still trying to get LabCA (matlab framework for EPCIS) to work
under windows 10. Based on the input from Freddie, I decided to try with
the Visual Studio compiler.
All went well with compiling the base EPICS, but still no success on the
LabCA (however now new error).
The setup is now
* Windows 10
* Visual Studio 2022 with c++
* Matlab R2022a
* epics-labca-labca_3_8_1
* EPICS version base-3.15.9
* EPICS_HOST_ARCH = windows-x64
Problem now seems to be regarding "No rule to make target 'gitstring.c',
needed by 'gitstring.obj'"  (full output from Make below)
I would be very happy if anyone which have succeeded in compiling LabCA
under windows 10, could give some hints to which setup works
Best regards
      Bo
Output from make is now:
d:\EPICS\epics-labca-labca_3_8_1>make
The system cannot find the path specified.
process_begin: CreateProcess(NULL, git describe, ...) failed.
makefile:24: pipe: No error
make -C ./configure install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/makeMakefile.pl
O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
      T_A=windows-x64 install
make[2]: Entering directory
'd:/EPICS/epics-labca-labca_3_8_1/configure/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/convertRelease.pl
checkRelease
echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
make[2]: Leaving directory
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
make -C ./ezca install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
O.windows-x64 ../..
'd:/EPICS/epics-labca-labca_3_8_1/ezca/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m ezca.d -I.
-I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
-I../../include/os/WIN32 -I../../include
-ID:/EPICS/base-3.15.9/include/compiler/msvc
-ID:/EPICS/base-3.15.9/include/os/WIN32
-ID:/EPICS/base-3.15.9/include                 ezca.obj ../ezca.c
cl               -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3        -MD
-DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I..
-I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include
-ID:/EPICS/base-3.15.9/include                 -c ../ezca.c
ezca.c
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(570): warning C4311: 'type
cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(575): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(612): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(618): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(713): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(715): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4905): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4934): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5032): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5034): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5529): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5546): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5590): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5595): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5697): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5716): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5755): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6963): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6999): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7191): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7217): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7263): warning C4311: 'type
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
-release  -MACHINE:X64      -out:ezcamt.dll -implib:ezcamt.lib
ezca.obj D:/EPICS/base-3.15.9/lib/windows-x64/ca.lib
D:/EPICS/base-3.15.9/lib/windows-x64/Com.lib
     Creating library ezcamt.lib and object ezcamt.exp
Generating code
Finished generating code
"Installing shared library ../../bin/windows-x64/ezcamt.dll"
"Installing library ../../lib/windows-x64/ezcamt.lib"
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
make -C ./glue install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
O.windows-x64 ../..
'd:/EPICS/epics-labca-labca_3_8_1/glue/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m ini.d -I.
-ID:/EPICS/base-3.15.9/include             -I../../ezca
-ID:/Matlab2022a/extern/include    ini.obj ../ini.cc
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m multiEzca.d
-I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
-ID:/Matlab2022a/extern/include    multiEzca.obj ../multiEzca.c
ctrlC-polled.d -I. -I../O.Common -I. -I. -I..
-I../../include    -ID:/EPICS/base-3.15.9/include/compiler/msvc
-ID:/Matlab2022a/extern/include    ctrlC-polled.obj ../ctrlC-polled.c
perl -CSD -MExtUtils::Command -e rm_f gitstring.c.new
perl > gitstring.c.new -e "print(\"const char *gitRevisionString =
\\\"labca_3_8_1 - ef74a39\\\";\n\")" > gitstring.c.new
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl  -m mglue.d -I.
-ID:/Matlab2022a/extern/include    mglue.obj ../mglue.c
cl -EHsc -GR          -DMATLAB_APP      -nologo -FC -D__STDC__=0
-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-
-W3 -w44355 -w44344 -w44251        -MD -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -TP  -I. -I../O.Common -I. -I. -I..
-ID:/Matlab2022a/extern/include    -c ../ini.cc
ini.cc
cl          -DMATLAB_APP      -nologo -FC -D__STDC__=0
-W3        -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common
-I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32
-ID:/Matlab2022a/extern/include    -c ../multiEzca.c
multiEzca.c
d:\EPICS\epics-labca-labca_3_8_1\glue\multiEzca.c(27): warning C4005:
'isnan': macro redefinition
D:\Windows Kits\10\include\10.0.22621.0\ucrt\corecrt_math.h(280): note:
see previous definition of 'isnan'
D:\Matlab2022a\extern\include\mex.h(197): warning C4005: 'printf': macro
redefinition
D:\EPICS\base-3.15.9\include\epicsStdio.h(41): note: see previous
definition of 'printf'
-ID:/Matlab2022a/extern/include    -c ../ctrlC-polled.c
ctrlC-polled.c
make[2]: *** No rule to make target 'gitstring.c', needed by
'gitstring.obj'.  Stop.
make[1]: *** [D:/EPICS/base-3.15.9/configure/RULES_ARCHS:58:
install.windows-x64] Error 2
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
make: *** [D:/EPICS/base-3.15.9/configure/RULES_DIRS:85: glue.install]
Error 2
On 19-12-2023 13:02, Freddie Akeroyd - STFC UKRI wrote:
Hi Boj,
I'm not a user of labca, but we do use EPICS on windows and I have used matlab in the past, so I'm basing my answers on this rather than anything I can actually test for you unfortunately
The program is failing to link as it cannot find some functions from the matlab mex/mx libraries, I see that libmx.lib and libmex.lib are included on the command line but these files will be in Microsoft import library format and gcc/mingw didn't used to read this format, hence why you may be getting undefined symbols. Normally with gcc/mingw  you would be linking as e.g.  -lmex   and it would locate a  libmex.dll.a file to reference libmex.dll    If you were using the visual studio window compiler then it may work better as .lib is its native format. Does matlab provide *.dll.a files or just *.lib and *.dll ? You can create a mingw compatible .dll.a file the following way from the mingw shell
      # create libmex.def
      gendef libmex.dll
      # create libmex.dll.a from libmex.def
      dlltool --def libmex.def  --output-lib libmex.dll.a
(in some cases the -k argument may also be needed with dlltool, add that if you still get link undefined errors using libmex.dll.a)
At one point I think it was possible to link directly against a dll in mingw and it would auto import, but I am not sure if that is still the case i.e. You would link against /d/Matlab2022a/extern/lib/win64/mingw64/libmx.dll rather than /d/Matlab2022a/extern/lib/win64/mingw64/libmx.lib  however creating a .dll.a is probably the better approach
Freddie
Sent: 19 December 2023 10:45
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>
Cc: Giovanni Franzini <[email protected]>; [email protected]
Dear Freddie and all
I looked a bit more carefully at the errors, and here are some details,
unfortunately I am not very skilled in either c/c++ programming or windows
programming, so that makes it hard for me to understand what is important.
The setup is:
* Windows 10
* MSYS2 MINGW64 compiler "complex" as recommended for the EPICS part
* Matlab R2022a
In the labca source code I have set
configure/RELEASE
       BASE_SUBDIR=
       EPICS_BASE=/home/boj/base-3.15.9/
       MATLABDIR = /d/Matlab2022a
       MATLIB_SUBDIR=win64/mingw64
In my .bash_profile for MSYS2 I have
       EPICS_HOST_ARCH=windows-x64-mingw
       PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
EPICS  command line tools works
Included at the end of this mail is the full output of make, but as I understand
it the problem is in the linking of mezcaglue.dll I get:
gcc          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -
Wall      -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common -I. -I.
-I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include    -
I/home/boj/base-3.15.9/include/compiler/gcc
-I/home/boj/base-3.15.9/include/os/WIN32
-I/home/boj/base-3.15.9/include             -I../../ezca -
I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c
g++ -o mezcaglue.dll -shared -Wl,--out-implib,libmezcaglue.dll.a
-L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw
-L/home/boj/base-3.15.9/lib/windows-x64-mingw
/d/Matlab2022a/extern/lib/win64/mingw64/libut.lib
/d/Matlab2022a/extern/lib/win64/mingw64/libmex.lib -m64 ini.obj
multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj -lezcamt -lca -lCom  -
luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-
mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe
: ini.obj:ini.cc:(.text+0x9b): undefined reference to `mexPrintf_800'
: ini.obj:ini.cc:(.text+0xfe): undefined reference to `mexCallMATLAB_800'
Which then continues with  "undefined reference to `XXXX" for many lines and
end with
collect2.exe: error: ld returned 1 exit status
make[2]: *** [/home/boj/base-3.15.9/configure/RULES_BUILD:292:
mezcaglue.dll] Error 1
'/home/boj/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
make[1]: *** [/home/boj/base-3.15.9/configure/RULES_ARCHS:58:
install.windows-x64-mingw] Error 2
make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/glue'
make: *** [/home/boj/base-3.15.9/configure/RULES_DIRS:85: glue.install]
Error 2
I hope this makes sence, and maybe can give a hint to what I am dooing
wrong.
Best regards
       Bo
Full output of make:
boj@dk1080799 MINGW64 ~/epics-labca-labca_3_8_1 $ make
make: git: No such file or directory
make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/configure'
perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/makeMakefile.pl
O.windows-x64-mingw ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-
x64-mingw -f ../Makefile TOP=../.. \
       T_A=windows-x64-mingw install
'/home/boj/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/convertRelease.pl
checkRelease
make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/configure'
make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/ezca'
'/home/boj/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall
-I/home/boj/base-3.15.9/include                  -MM -MF ezca.d -MT ezca.obj
../ezca.c gcc             -D_MINGW -D__USE_MINGW_ANSI_STDIO     -O3 -Wall
-I/home/boj/base-3.15.9/include                 -o ezca.obj -c ../ezca.c
../ezca.c: In function 'ezcaLock':
../ezca.c:89:25: warning: cast from pointer to integer of different size [-
Wpointer-to-int-cast]
      89 |                         (unsigned long)epicsThreadGetIdSelf()); \
../ezca.c:570:9: note: in expansion of macro 'EZCA_LOCK'
     570 |         EZCA_LOCK();
../ezca.c: In function 'ezcaUnlock':
../ezca.c:575:9: note: in expansion of macro 'EZCA_LOCK'
     575 |         EZCA_LOCK();
../ezca.c: In function 'ezcaPollCbInstall':
../ezca.c:612:9: note: in expansion of macro 'EZCA_LOCK'
     612 |         EZCA_LOCK();
../ezca.c:611:1: warning: this 'if' clause does not guard...
[-Wmisleading-indentation]
     611 | if ( (i=Initialized) )
../ezca.c:614:9: note: ...this statement, but the latter is misleadingly indented
as if it were guar ded by the 'if'
     614 |         rval = pollCb;
../ezca.c:97:25: warning: cast from pointer to integer of different size [-
      97 |                         (unsigned long)epicsThreadGetIdSelf()); \
../ezca.c:618:9: note: in expansion of macro 'EZCA_UNLOCK'
     618 |         EZCA_UNLOCK();
../ezca.c:617:1: warning: this 'if' clause does not guard...
     617 | if (i)
../ezca.c:620:9: note: ...this statement, but the latter is misleadingly indented
     620 |         return rval;
../ezca.c: In function 'ezcaEndGroupWithReport':
../ezca.c:713:33: note: in expansion of macro 'EZCA_LOCK'
     713 |                                 EZCA_LOCK(); /* make *sure* mutex is not
relinquished by add ing a nest count */
../ezca.c:715:33: note: in expansion of macro 'EZCA_UNLOCK'
     715 |                                 EZCA_UNLOCK();
../ezca.c:966:13: warning: this 'if' clause does not guard...
     966 |             if (Trace || Debug)
../ezca.c:104:29: note: ...this statement, but the latter is misleadingly indented
as if it were gua rded by the 'if'
     104 | #define MARK_OUTSTANDING(n) do { if ( (ezcaOutstanding = (n)) )
ca_flush_io(); } while (0)
../ezca.c:969:17: note: in expansion of macro 'MARK_OUTSTANDING'
     969 |                 MARK_OUTSTANDING(needs_work);
../ezca.c:1063:29: warning: this 'if' clause does not guard...
    1063 |                             if (AutoErrorMessage)
../ezca.c:1066:33: note: ...this statement, but the latter is misleadingly
indented as if it were gu arded by the 'if'
    1066 |                                 if ( MONBLOCK == wp->worktype && wp->pval )
../ezca.c: In function 'prologue':
../ezca.c:4905:9: note: in expansion of macro 'EZCA_LOCK'
    4905 |         EZCA_LOCK();
../ezca.c: In function 'epilogue':
../ezca.c:4934:9: note: in expansion of macro 'EZCA_UNLOCK'
    4934 |         EZCA_UNLOCK();
../ezca.c: In function 'EzcaClearChannel':
../ezca.c:5032:9: note: in expansion of macro 'EZCA_UNLOCK'
    5032 |         EZCA_UNLOCK();
../ezca.c:5034:9: note: in expansion of macro 'EZCA_LOCK'
    5034 |         EZCA_LOCK();
../ezca.c: In function 'EzcaPendEvent':
../ezca.c:5519:5: warning: this 'if' clause does not guard...
    5519 |     if (Trace || Debug)
../ezca.c:5522:9: note: ...this statement, but the latter is misleadingly indented
    5522 |         if ( pollCb && pollCb() ) {
../ezca.c:5529:1: note: in expansion of macro 'EZCA_UNLOCK'
    5529 | EZCA_UNLOCK();
../ezca.c:5546:1: note: in expansion of macro 'EZCA_LOCK'
    5546 | EZCA_LOCK();
../ezca.c: In function 'EzcaPendIO':
../ezca.c:5584:5: warning: this 'if' clause does not guard...
    5584 |     if (Trace || Debug)
../ezca.c:5587:9: note: ...this statement, but the latter is misleadingly indented
    5587 |         if ( pollCb && pollCb() ) {
../ezca.c:5590:1: note: in expansion of macro 'EZCA_UNLOCK'
    5590 | EZCA_UNLOCK();
../ezca.c:5595:1: note: in expansion of macro 'EZCA_LOCK'
    5595 | EZCA_LOCK();
../ezca.c: In function 'my_connection_callback':
../ezca.c:5697:1: note: in expansion of macro 'EZCA_LOCK'
    5697 | EZCA_LOCK();
../ezca.c:5716:1: note: in expansion of macro 'EZCA_UNLOCK'
    5716 | EZCA_UNLOCK();
../ezca.c: In function 'my_get_callback':
../ezca.c:5755:1: note: in expansion of macro 'EZCA_LOCK'
    5755 | EZCA_LOCK();
../ezca.c:6949:13: warning: this 'if' clause does not guard...
    6949 |             if (Trace || Debug)
../ezca.c:6951:17: note: ...this statement, but the latter is misleadingly
    6951 |                 recycle_work(wp);
../ezca.c:6963:1: note: in expansion of macro 'EZCA_UNLOCK'
    6963 | EZCA_UNLOCK();
../ezca.c: In function 'my_monitor_callback':
../ezca.c:6999:1: note: in expansion of macro 'EZCA_LOCK'
    6999 | EZCA_LOCK();
../ezca.c:7191:1: note: in expansion of macro 'EZCA_UNLOCK'
    7191 | EZCA_UNLOCK();
../ezca.c: In function 'my_put_callback':
../ezca.c:7217:1: note: in expansion of macro 'EZCA_LOCK'
    7217 | EZCA_LOCK();
../ezca.c:7249:13: warning: this 'if' clause does not guard...
    7249 |             if (Trace || Debug)
../ezca.c:7251:17: note: ...this statement, but the latter is misleadingly
    7251 |                 recycle_work(wp);
../ezca.c:7263:1: note: in expansion of macro 'EZCA_UNLOCK'
    7263 | EZCA_UNLOCK();
../ezca.c: In function 'print_discarded_channels':
../ezca.c:7886:5: warning: this 'for' clause does not guard...
    7886 |     for (cp = Discarded_channels; cp; cp = cp->next)
../ezca.c:7888:9: note: ...this statement, but the latter is misleadingly indented
as if it were gua rded by the 'for'
    7888 |         printf("\n");
g++ -o ezcamt.dll -shared -Wl,--out-implib,libezcamt.dll.a
-L/home/boj/base-3.15.9/lib/windows-x64-mingw -m64
ezca.obj    -lca -lCom      -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
Installing shared library ../../bin/windows-x64-mingw/ezcamt.dll
mkdir ../../bin
mkdir ../../bin/windows-x64-mingw
Installing DLL stub library ../../lib/windows-x64-mingw/libezcamt.dll.a
mkdir ../../lib
mkdir ../../lib/windows-x64-mingw
make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/ezca'
make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/glue'
make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
g++          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3
-Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common
-I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32
-I../../include -I/home/boj/base-3.15.9/include/compiler/gcc
-I/d/Matlab2022a/extern/include     -MM -MF ini.d -MT ini.obj ../ini.cc
-I../O.Common -I. -I. -I.. -I../../include/compiler/gcc
-I/d/Matlab2022a/extern/include     -MM -MF multiEzca.d -MT
-I/d/Matlab2022a/extern/include     -MM -MF ctrlC-polled.d -MT
-I/d/Matlab2022a/extern/include     -MM -MF gitstring.d -MT
gitstring.obj gitstring.c
-I/d/Matlab2022a/extern/include     -MM -MF mglue.d -MT mglue.obj
../mglue.c
-I/d/Matlab2022a/extern/include    -o ini.obj -c ../ini.cc
-I/d/Matlab2022a/extern/include    -o multiEzca.obj -c ../multiEzca.c
../multiEzca.c:27: warning: "isnan" redefined
      27 | #define isnan _isnan
In file included from ../multiEzca.c:13:
C:/msys64/mingw64/include/math.h:586: note: this is the location of the
previous definition
     586 | #define isnan(x) \
In file included from ../multiEzca.c:32:
D:/Matlab2022a/extern/include/mex.h:197: warning: "printf" redefined
     197 | #define printf mexPrintf
In file included from ../multiEzca.c:24:
C:/msys64/home/boj/base-3.15.9/include/epicsStdio.h:41: note: this is
the location of the previous d
efinition
      41 | #  define printf epicsStdoutPrintf
-I/d/Matlab2022a/extern/include    -o ctrlC-polled.obj -c ../ctrlC-polled.c
-I/d/Matlab2022a/extern/include    -o gitstring.obj -c gitstring.c
-I/d/Matlab2022a/extern/include    -o mglue.obj -c ../mglue.c
ini.obj multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj
-lezcamt -lca -lCom  -luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32
-lwinmm
: ini.obj:ini.cc:(.text+0x126): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x1d9): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x256): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x37e): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x39e): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x4e6): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x506): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x5d0): undefined reference to
`mexCallMATLABWithTrap_800'
: ini.obj:ini.cc:(.text+0x5f7): undefined reference to `mxDestroyArray_800'
: ini.obj:ini.cc:(.text+0x678): undefined reference to `mexLock_800'
: ini.obj:ini.cc:(.text+0x6b1): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0x726): undefined reference to `mxIsChar_800'
: ini.obj:ini.cc:(.text+0x74e): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0x796): undefined reference to `mxGetN_800'
: ini.obj:ini.cc:(.text+0x7b9): undefined reference to `mxGetString_800'
: ini.obj:ini.cc:(.text+0x997): undefined reference to
: ini.obj:ini.cc:(.text+0x9c2): undefined reference to `mxDestroyArray_800'
: ini.obj:ini.cc:(.text+0xa48): undefined reference to `mexLock_800'
: ini.obj:ini.cc:(.text+0xa81): undefined reference to `mexCallMATLAB_800'
: ini.obj:ini.cc:(.text+0xb06): undefined reference to `mxIsChar_800'
: ini.obj:ini.cc:(.text+0xb36): undefined reference to `mxGetScalar_800'
: ini.obj:ini.cc:(.text+0xb86): undefined reference to `mxGetN_800'
: ini.obj:ini.cc:(.text+0xba9): undefined reference to `mxGetString_800'
: multiEzca.obj:multiEzca.c:(.text+0x11d): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x145): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3dd): undefined reference to
`mexPrintf_800'
: multiEzca.obj:multiEzca.c:(.text+0x5c3): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x5db): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x6ea): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x914): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x91e): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x928): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0xe84): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1062): undefined reference to
`mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x107a): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1238): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1242): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x124c): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1256): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1260): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x126a): more undefined references to
`mxFree_800' follow
: multiEzca.obj:multiEzca.c:(.text+0x1326): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1346): undefined reference to
`mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x136c): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x138e): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1847): undefined reference to
`mexPrintf_800'
: multiEzca.obj:multiEzca.c:(.text+0x187f): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1e19): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x1f51): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x1fe7): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x2063): undefined reference to
`mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x322e): undefined reference to
`mxCalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x335b): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x35e4): undefined reference to
`mxMalloc_800'
: multiEzca.obj:multiEzca.c:(.text+0x365a): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3662): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x39d7): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3ad4): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3b42): undefined reference to
`mxFree_800'
: multiEzca.obj:multiEzca.c:(.text+0x3b68): more undefined references to
`mxFree_800' follow
: ctrlC-polled.obj:ctrlC-polled.c:(.text+0x5): undefined reference to
`utHandlePendingInterrupt'
: mglue.obj:mglue.c:(.text+0x29): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x38): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x9c): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0xac): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0xbc): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0xd3): undefined reference to `mxCalloc_800'
: mglue.obj:mglue.c:(.text+0xf4): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x100): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x10e): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x11b): undefined reference to `mxMalloc_800'
: mglue.obj:mglue.c:(.text+0x136): undefined reference to `mxGetString_800'
: mglue.obj:mglue.c:(.text+0x156): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x165): undefined reference to `mxGetCell_800'
: mglue.obj:mglue.c:(.text+0x1a9): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x1b8): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x1e4): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x214): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x241): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x24c): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x266): undefined reference to `mxCalloc_800'
: mglue.obj:mglue.c:(.text+0x2e4): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x404): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x41b): undefined reference to `mxGetString_800'
: mglue.obj:mglue.c:(.text+0x510): undefined reference to
: mglue.obj:mglue.c:(.text+0x581): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x58e): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x59b): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x5ae): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x5d5): undefined reference to `mxCalloc_800'
: mglue.obj:mglue.c:(.text+0x5fc): undefined reference to `mxGetM_800'
: mglue.obj:mglue.c:(.text+0x60a): undefined reference to `mxGetN_800'
: mglue.obj:mglue.c:(.text+0x617): undefined reference to `mxMalloc_800'
: mglue.obj:mglue.c:(.text+0x632): undefined reference to `mxGetString_800'
: mglue.obj:mglue.c:(.text+0x652): undefined reference to `mxGetCell_800'
: mglue.obj:mglue.c:(.text+0x65d): undefined reference to `mxIsChar_800'
: mglue.obj:mglue.c:(.text+0x699): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x6a6): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x6b3): undefined reference to
: mglue.obj:mglue.c:(.text+0x6d9): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x6ea): undefined reference to `mxFree_800'
: mglue.obj:mglue.c:(.text+0x71b): undefined reference to
`mxCreateCellMatrix_800'
: mglue.obj:mglue.c:(.text+0x732): undefined reference to
`mxDuplicateArray_800'
: mglue.obj:mglue.c:(.text+0x73f): undefined reference to `mxSetCell_800'
: mglue.obj:mglue.c:(.text+0x759): undefined reference to `mxIsCell_800'
: mglue.obj:mglue.c:(.text+0x76d): undefined reference to `mxIsDouble_800'
: mglue.obj:mglue.c:(.text+0x8b5): undefined reference to `mxGetPr_800'
Error 2
On 18-12-2023 18:49, Freddie Akeroyd - STFC UKRI wrote:
Hi Bo,
Do you see the same error as Giovanni saw, or are you getting a different
build failure?
Freddie
RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
Re: LabCA for MATLAB Installation error boj via Tech-talk
RE: LabCA for MATLAB Installation error Mark Rivers via Tech-talk
Prev: RE: LabCA for MATLAB Installation error Mark Rivers via Tech-talk
Next: Re: Question about cross compile of epics Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
