Yes https://github.com/till-s/epics-labca/blob/7915ca4769f49eee1ceba77493ee3cda6bf2a51b/glue/Makefile#L204 uses "(" to run commands in a subprocess and that is /bin/sh specific
Bo, does applying this change help?
https://github.com/till-s/epics-labca/compare/master...FreddieAkeroyd:epics-labca:fix_windows_quoting
Freddie
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Michael Davidsaver via Tech-talk
Sent: 03 January 2024 01:29
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: Giovanni Franzini <giovanni.franzini at lnf.infn.it>; tech-talk at aps.anl.gov
Subject: Re: LabCA for MATLAB Installation error
On 1/2/24 08:28, Mark Rivers via Tech-talk wrote:
> Hi Bo,
> The fatal error you are getting is because gitstring.c does not exist. But I think that is due to a non-fatal error earlier in the output:
> perl -MFile::Compare -e 'exit( compare(@ARGV[0],@ARGV[1]) )'
> gitstring.c.new gitstring.c || (perl -CSD -MExtUtils::Command -e rm_f
> gitstring.c; perl -e 'rename("gitstring.c.new","gitstring.c")')
> ') was unexpected at this time.
Isn't "... was unexpected at this time" a cmd shell error?
I guess this Makefile assumes SHELL=/bin/sh ?
> So I think it is trying to rename gitstring.c.new to gitstring.c and that is failing. I think a perl expert is needed to help here?
> Mark
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of boj via Tech-talk
> Sent: Tuesday, January 2, 2024 9:03 AM
> To: tech-talk at aps.anl.gov
> Dear all
> I am still trying to get LabCA (matlab framework for EPCIS) to work
> under windows 10. Based on the input from Freddie, I decided to try with
> the Visual Studio compiler.
> All went well with compiling the base EPICS, but still no success on the
> LabCA (however now new error).
> The setup is now
> * Windows 10
> * Visual Studio 2022 with c++
> * Matlab R2022a
> * epics-labca-labca_3_8_1
> * EPICS version base-3.15.9
> * EPICS_HOST_ARCH = windows-x64
> Problem now seems to be regarding "No rule to make target 'gitstring.c',
> needed by 'gitstring.obj'" (full output from Make below)
> I would be very happy if anyone which have succeeded in compiling LabCA
> under windows 10, could give some hints to which setup works
> Best regards
> Bo
> Output from make is now:
> d:\EPICS\epics-labca-labca_3_8_1>make
> The system cannot find the path specified.
> process_begin: CreateProcess(NULL, git describe, ...) failed.
> makefile:24: pipe: No error
> make -C ./configure install
> make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/makeMakefile.pl
> O.windows-x64 ../..
> perl -CSD -MExtUtils::Command -e mkpath O.Common
> make -C O.windows-x64 -f ../Makefile TOP=../.. \
> T_A=windows-x64 install
> make[2]: Entering directory
> 'd:/EPICS/epics-labca-labca_3_8_1/configure/O.windows-x64'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/convertRelease.pl
> checkRelease
> echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
> make[2]: Leaving directory
> make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
> make -C ./ezca install
> make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
> O.windows-x64 ../..
> 'd:/EPICS/epics-labca-labca_3_8_1/ezca/O.windows-x64'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m ezca.d -I.
> -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
> -I../../include/os/WIN32 -I../../include
> -ID:/EPICS/base-3.15.9/include/compiler/msvc
> -ID:/EPICS/base-3.15.9/include/os/WIN32
> -ID:/EPICS/base-3.15.9/include ezca.obj ../ezca.c
> cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
> -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD
> -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I..
> -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include
> -ID:/EPICS/base-3.15.9/include -c ../ezca.c
> ezca.c
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(570): warning C4311: 'type
> cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(575): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(612): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(618): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(713): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(715): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4905): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4934): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5032): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5034): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5529): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5546): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5590): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5595): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5697): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5716): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5755): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6963): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6999): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7191): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7217): warning C4311: 'type
> d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7263): warning C4311: 'type
> link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
> -release -MACHINE:X64 -out:ezcamt.dll -implib:ezcamt.lib
> ezca.obj D:/EPICS/base-3.15.9/lib/windows-x64/ca.lib
> D:/EPICS/base-3.15.9/lib/windows-x64/Com.lib
> Creating library ezcamt.lib and object ezcamt.exp
> Generating code
> Finished generating code
> "Installing shared library ../../bin/windows-x64/ezcamt.dll"
> "Installing library ../../lib/windows-x64/ezcamt.lib"
> make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
> make -C ./glue install
> make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
> O.windows-x64 ../..
> 'd:/EPICS/epics-labca-labca_3_8_1/glue/O.windows-x64'
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m ini.d -I.
> -ID:/EPICS/base-3.15.9/include -I../../ezca
> -ID:/Matlab2022a/extern/include ini.obj ../ini.cc
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m multiEzca.d
> -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
> -ID:/Matlab2022a/extern/include multiEzca.obj ../multiEzca.c
> ctrlC-polled.d -I. -I../O.Common -I. -I. -I..
> -I../../include -ID:/EPICS/base-3.15.9/include/compiler/msvc
> -ID:/Matlab2022a/extern/include ctrlC-polled.obj ../ctrlC-polled.c
> perl -CSD -MExtUtils::Command -e rm_f gitstring.c.new
> perl > gitstring.c.new -e "print(\"const char *gitRevisionString =
> \\\"labca_3_8_1 - ef74a39\\\";\n\")" > gitstring.c.new
> perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m mglue.d -I.
> -ID:/Matlab2022a/extern/include mglue.obj ../mglue.c
> cl -EHsc -GR -DMATLAB_APP -nologo -FC -D__STDC__=0
> -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy-
> -W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL
> -DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I..
> -ID:/Matlab2022a/extern/include -c ../ini.cc
> ini.cc
> cl -DMATLAB_APP -nologo -FC -D__STDC__=0
> -W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common
> -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32
> -ID:/Matlab2022a/extern/include -c ../multiEzca.c
> multiEzca.c
> d:\EPICS\epics-labca-labca_3_8_1\glue\multiEzca.c(27): warning C4005:
> 'isnan': macro redefinition
> D:\Windows Kits\10\include\10.0.22621.0\ucrt\corecrt_math.h(280): note:
> see previous definition of 'isnan'
> D:\Matlab2022a\extern\include\mex.h(197): warning C4005: 'printf': macro
> redefinition
> D:\EPICS\base-3.15.9\include\epicsStdio.h(41): note: see previous
> definition of 'printf'
> -ID:/Matlab2022a/extern/include -c ../ctrlC-polled.c
> ctrlC-polled.c
> make[2]: *** No rule to make target 'gitstring.c', needed by
> 'gitstring.obj'. Stop.
> make[1]: *** [D:/EPICS/base-3.15.9/configure/RULES_ARCHS:58:
> install.windows-x64] Error 2
> make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
> make: *** [D:/EPICS/base-3.15.9/configure/RULES_DIRS:85: glue.install]
> Error 2
> On 19-12-2023 13:02, Freddie Akeroyd - STFC UKRI wrote:
>> Hi Boj,
>> I'm not a user of labca, but we do use EPICS on windows and I have used matlab in the past, so I'm basing my answers on this rather than anything I can actually test for you unfortunately
>> The program is failing to link as it cannot find some functions from the matlab mex/mx libraries, I see that libmx.lib and libmex.lib are included on the command line but these files will be in Microsoft import library format and gcc/mingw didn't used to read this format, hence why you may be getting undefined symbols. Normally with gcc/mingw you would be linking as e.g. -lmex and it would locate a libmex.dll.a file to reference libmex.dll If you were using the visual studio window compiler then it may work better as .lib is its native format. Does matlab provide *.dll.a files or just *.lib and *.dll ? You can create a mingw compatible .dll.a file the following way from the mingw shell
>> # create libmex.def
>> gendef libmex.dll
>> # create libmex.dll.a from libmex.def
>> dlltool --def libmex.def --output-lib libmex.dll.a
>> (in some cases the -k argument may also be needed with dlltool, add that if you still get link undefined errors using libmex.dll.a)
>> At one point I think it was possible to link directly against a dll in mingw and it would auto import, but I am not sure if that is still the case i.e. You would link against /d/Matlab2022a/extern/lib/win64/mingw64/libmx.dll rather than /d/Matlab2022a/extern/lib/win64/mingw64/libmx.lib however creating a .dll.a is probably the better approach
>> Regards,
>> Freddie
>>> From: boj <lister at f77.dk>
>>> Sent: 19 December 2023 10:45
>>> To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>
>>> Dear Freddie and all
>>> I looked a bit more carefully at the errors, and here are some details,
>>> unfortunately I am not very skilled in either c/c++ programming or windows
>>> programming, so that makes it hard for me to understand what is important.
>>> The setup is:
>>> * Windows 10
>>> * MSYS2 MINGW64 compiler "complex" as recommended for the EPICS part
>>> * Matlab R2022a
>>> In the labca source code I have set
>>> configure/RELEASE
>>> BASE_SUBDIR=
>>> EPICS_BASE=/home/boj/base-3.15.9/
>>> MATLABDIR = /d/Matlab2022a
>>> MATLIB_SUBDIR=win64/mingw64
>>> In my .bash_profile for MSYS2 I have
>>> EPICS_HOST_ARCH=windows-x64-mingw
>>> PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
>>> EPICS command line tools works
>>> Included at the end of this mail is the full output of make, but as I understand
>>> it the problem is in the linking of mezcaglue.dll I get:
>>> gcc -DMATLAB_APP -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3 -
>>> Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I.
>>> -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -
>>> I/home/boj/base-3.15.9/include/compiler/gcc
>>> -I/home/boj/base-3.15.9/include/os/WIN32
>>> -I/home/boj/base-3.15.9/include -I../../ezca -
>>> I/d/Matlab2022a/extern/include -o mglue.obj -c ../mglue.c
>>> g++ -o mezcaglue.dll -shared -Wl,--out-implib,libmezcaglue.dll.a
>>> -L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw
>>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw
>>> /d/Matlab2022a/extern/lib/win64/mingw64/libut.lib
>>> /d/Matlab2022a/extern/lib/win64/mingw64/libmex.lib -m64 ini.obj
>>> multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj -lezcamt -lca -lCom -
>>> luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>>> C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-
>>> mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe
>>> : ini.obj:ini.cc:(.text+0x9b): undefined reference to `mexPrintf_800'
>>> : ini.obj:ini.cc:(.text+0xfe): undefined reference to `mexCallMATLAB_800'
>>> Which then continues with "undefined reference to `XXXX" for many lines and
>>> end with
>>> collect2.exe: error: ld returned 1 exit status
>>> make[2]: *** [/home/boj/base-3.15.9/configure/RULES_BUILD:292:
>>> mezcaglue.dll] Error 1
>>> '/home/boj/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
>>> make[1]: *** [/home/boj/base-3.15.9/configure/RULES_ARCHS:58:
>>> install.windows-x64-mingw] Error 2
>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/glue'
>>> make: *** [/home/boj/base-3.15.9/configure/RULES_DIRS:85: glue.install]
>>> Error 2
>>> I hope this makes sence, and maybe can give a hint to what I am dooing
>>> wrong.
>>> Best regards
>>> Bo
>>> Full output of make:
>>> boj@dk1080799 MINGW64 ~/epics-labca-labca_3_8_1 $ make
>>> make: git: No such file or directory
>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/configure'
>>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/makeMakefile.pl
>>> O.windows-x64-mingw ../..
>>> perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-
>>> x64-mingw -f ../Makefile TOP=../.. \
>>> T_A=windows-x64-mingw install
>>> '/home/boj/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
>>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/convertRelease.pl
>>> checkRelease
>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/configure'
>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>>> '/home/boj/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
>>> gcc -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3 -Wall
>>> -I/home/boj/base-3.15.9/include -MM -MF ezca.d -MT ezca.obj
>>> ../ezca.c gcc -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3 -Wall
>>> -I/home/boj/base-3.15.9/include -o ezca.obj -c ../ezca.c
>>> ../ezca.c: In function 'ezcaLock':
>>> ../ezca.c:89:25: warning: cast from pointer to integer of different size [-
>>> Wpointer-to-int-cast]
>>> 89 | (unsigned long)epicsThreadGetIdSelf()); \
>>> ../ezca.c:570:9: note: in expansion of macro 'EZCA_LOCK'
>>> 570 | EZCA_LOCK();
>>> ../ezca.c: In function 'ezcaUnlock':
>>> ../ezca.c:575:9: note: in expansion of macro 'EZCA_LOCK'
>>> 575 | EZCA_LOCK();
>>> ../ezca.c: In function 'ezcaPollCbInstall':
>>> ../ezca.c:612:9: note: in expansion of macro 'EZCA_LOCK'
>>> 612 | EZCA_LOCK();
>>> ../ezca.c:611:1: warning: this 'if' clause does not guard...
>>> [-Wmisleading-indentation]
>>> 611 | if ( (i=Initialized) )
>>> ../ezca.c:614:9: note: ...this statement, but the latter is misleadingly indented
>>> as if it were guar ded by the 'if'
>>> 614 | rval = pollCb;
>>> ../ezca.c:97:25: warning: cast from pointer to integer of different size [-
>>> 97 | (unsigned long)epicsThreadGetIdSelf()); \
>>> ../ezca.c:618:9: note: in expansion of macro 'EZCA_UNLOCK'
>>> 618 | EZCA_UNLOCK();
>>> ../ezca.c:617:1: warning: this 'if' clause does not guard...
>>> 617 | if (i)
>>> ../ezca.c:620:9: note: ...this statement, but the latter is misleadingly indented
>>> 620 | return rval;
>>> ../ezca.c: In function 'ezcaEndGroupWithReport':
>>> ../ezca.c:713:33: note: in expansion of macro 'EZCA_LOCK'
>>> 713 | EZCA_LOCK(); /* make *sure* mutex is not
>>> relinquished by add ing a nest count */
>>> ../ezca.c:715:33: note: in expansion of macro 'EZCA_UNLOCK'
>>> 715 | EZCA_UNLOCK();
>>> ../ezca.c:966:13: warning: this 'if' clause does not guard...
>>> 966 | if (Trace || Debug)
>>> ../ezca.c:104:29: note: ...this statement, but the latter is misleadingly indented
>>> as if it were gua rded by the 'if'
>>> 104 | #define MARK_OUTSTANDING(n) do { if ( (ezcaOutstanding = (n)) )
>>> ca_flush_io(); } while (0)
>>> ../ezca.c:969:17: note: in expansion of macro 'MARK_OUTSTANDING'
>>> 969 | MARK_OUTSTANDING(needs_work);
>>> ../ezca.c:1063:29: warning: this 'if' clause does not guard...
>>> 1063 | if (AutoErrorMessage)
>>> ../ezca.c:1066:33: note: ...this statement, but the latter is misleadingly
>>> indented as if it were gu arded by the 'if'
>>> 1066 | if ( MONBLOCK == wp->worktype && wp->pval )
>>> ../ezca.c: In function 'prologue':
>>> ../ezca.c:4905:9: note: in expansion of macro 'EZCA_LOCK'
>>> 4905 | EZCA_LOCK();
>>> ../ezca.c: In function 'epilogue':
>>> ../ezca.c:4934:9: note: in expansion of macro 'EZCA_UNLOCK'
>>> 4934 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'EzcaClearChannel':
>>> ../ezca.c:5032:9: note: in expansion of macro 'EZCA_UNLOCK'
>>> 5032 | EZCA_UNLOCK();
>>> ../ezca.c:5034:9: note: in expansion of macro 'EZCA_LOCK'
>>> 5034 | EZCA_LOCK();
>>> ../ezca.c: In function 'EzcaPendEvent':
>>> ../ezca.c:5519:5: warning: this 'if' clause does not guard...
>>> 5519 | if (Trace || Debug)
>>> ../ezca.c:5522:9: note: ...this statement, but the latter is misleadingly indented
>>> 5522 | if ( pollCb && pollCb() ) {
>>> ../ezca.c:5529:1: note: in expansion of macro 'EZCA_UNLOCK'
>>> 5529 | EZCA_UNLOCK();
>>> ../ezca.c:5546:1: note: in expansion of macro 'EZCA_LOCK'
>>> 5546 | EZCA_LOCK();
>>> ../ezca.c: In function 'EzcaPendIO':
>>> ../ezca.c:5584:5: warning: this 'if' clause does not guard...
>>> 5584 | if (Trace || Debug)
>>> ../ezca.c:5587:9: note: ...this statement, but the latter is misleadingly indented
>>> 5587 | if ( pollCb && pollCb() ) {
>>> ../ezca.c:5590:1: note: in expansion of macro 'EZCA_UNLOCK'
>>> 5590 | EZCA_UNLOCK();
>>> ../ezca.c:5595:1: note: in expansion of macro 'EZCA_LOCK'
>>> 5595 | EZCA_LOCK();
>>> ../ezca.c: In function 'my_connection_callback':
>>> ../ezca.c:5697:1: note: in expansion of macro 'EZCA_LOCK'
>>> 5697 | EZCA_LOCK();
>>> ../ezca.c:5716:1: note: in expansion of macro 'EZCA_UNLOCK'
>>> 5716 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'my_get_callback':
>>> ../ezca.c:5755:1: note: in expansion of macro 'EZCA_LOCK'
>>> 5755 | EZCA_LOCK();
>>> ../ezca.c:6949:13: warning: this 'if' clause does not guard...
>>> 6949 | if (Trace || Debug)
>>> ../ezca.c:6951:17: note: ...this statement, but the latter is misleadingly
>>> 6951 | recycle_work(wp);
>>> ../ezca.c:6963:1: note: in expansion of macro 'EZCA_UNLOCK'
>>> 6963 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'my_monitor_callback':
>>> ../ezca.c:6999:1: note: in expansion of macro 'EZCA_LOCK'
>>> 6999 | EZCA_LOCK();
>>> ../ezca.c:7191:1: note: in expansion of macro 'EZCA_UNLOCK'
>>> 7191 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'my_put_callback':
>>> ../ezca.c:7217:1: note: in expansion of macro 'EZCA_LOCK'
>>> 7217 | EZCA_LOCK();
>>> ../ezca.c:7249:13: warning: this 'if' clause does not guard...
>>> 7249 | if (Trace || Debug)
>>> ../ezca.c:7251:17: note: ...this statement, but the latter is misleadingly
>>> 7251 | recycle_work(wp);
>>> ../ezca.c:7263:1: note: in expansion of macro 'EZCA_UNLOCK'
>>> 7263 | EZCA_UNLOCK();
>>> ../ezca.c: In function 'print_discarded_channels':
>>> ../ezca.c:7886:5: warning: this 'for' clause does not guard...
>>> 7886 | for (cp = Discarded_channels; cp; cp = cp->next)
>>> ../ezca.c:7888:9: note: ...this statement, but the latter is misleadingly indented
>>> as if it were gua rded by the 'for'
>>> 7888 | printf("\n");
>>> g++ -o ezcamt.dll -shared -Wl,--out-implib,libezcamt.dll.a
>>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw -m64
>>> ezca.obj -lca -lCom -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>>> Installing shared library ../../bin/windows-x64-mingw/ezcamt.dll
>>> mkdir ../../bin
>>> mkdir ../../bin/windows-x64-mingw
>>> Installing DLL stub library ../../lib/windows-x64-mingw/libezcamt.dll.a
>>> mkdir ../../lib
>>> mkdir ../../lib/windows-x64-mingw
>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/glue'
>>> make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
>>> g++ -DMATLAB_APP -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3
>>> -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common
>>> -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32
>>> -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc
>>> -I/d/Matlab2022a/extern/include -MM -MF ini.d -MT ini.obj ../ini.cc
>>> -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc
>>> -I/d/Matlab2022a/extern/include -MM -MF multiEzca.d -MT
>>> -I/d/Matlab2022a/extern/include -MM -MF ctrlC-polled.d -MT
>>> -I/d/Matlab2022a/extern/include -MM -MF gitstring.d -MT
>>> gitstring.obj gitstring.c
>>> -I/d/Matlab2022a/extern/include -MM -MF mglue.d -MT mglue.obj
>>> ../mglue.c
>>> -I/d/Matlab2022a/extern/include -o ini.obj -c ../ini.cc
>>> -I/d/Matlab2022a/extern/include -o multiEzca.obj -c ../multiEzca.c
>>> ../multiEzca.c:27: warning: "isnan" redefined
>>> 27 | #define isnan _isnan
>>> In file included from ../multiEzca.c:13:
>>> C:/msys64/mingw64/include/math.h:586: note: this is the location of the
>>> previous definition
>>> 586 | #define isnan(x) \
>>> In file included from ../multiEzca.c:32:
>>> D:/Matlab2022a/extern/include/mex.h:197: warning: "printf" redefined
>>> 197 | #define printf mexPrintf
>>> In file included from ../multiEzca.c:24:
>>> C:/msys64/home/boj/base-3.15.9/include/epicsStdio.h:41: note: this is
>>> the location of the previous d
>>> efinition
>>> 41 | # define printf epicsStdoutPrintf
>>> -I/d/Matlab2022a/extern/include -o ctrlC-polled.obj -c ../ctrlC-polled.c
>>> -I/d/Matlab2022a/extern/include -o gitstring.obj -c gitstring.c
>>> -I/d/Matlab2022a/extern/include -o mglue.obj -c ../mglue.c
>>> ini.obj multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj
>>> -lezcamt -lca -lCom -luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32
>>> -lwinmm
>>> : ini.obj:ini.cc:(.text+0x126): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x1d9): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x256): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x37e): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x39e): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x4e6): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x506): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x5d0): undefined reference to
>>> `mexCallMATLABWithTrap_800'
>>> : ini.obj:ini.cc:(.text+0x5f7): undefined reference to `mxDestroyArray_800'
>>> : ini.obj:ini.cc:(.text+0x678): undefined reference to `mexLock_800'
>>> : ini.obj:ini.cc:(.text+0x6b1): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0x726): undefined reference to `mxIsChar_800'
>>> : ini.obj:ini.cc:(.text+0x74e): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0x796): undefined reference to `mxGetN_800'
>>> : ini.obj:ini.cc:(.text+0x7b9): undefined reference to `mxGetString_800'
>>> : ini.obj:ini.cc:(.text+0x997): undefined reference to
>>> : ini.obj:ini.cc:(.text+0x9c2): undefined reference to `mxDestroyArray_800'
>>> : ini.obj:ini.cc:(.text+0xa48): undefined reference to `mexLock_800'
>>> : ini.obj:ini.cc:(.text+0xa81): undefined reference to `mexCallMATLAB_800'
>>> : ini.obj:ini.cc:(.text+0xb06): undefined reference to `mxIsChar_800'
>>> : ini.obj:ini.cc:(.text+0xb36): undefined reference to `mxGetScalar_800'
>>> : ini.obj:ini.cc:(.text+0xb86): undefined reference to `mxGetN_800'
>>> : ini.obj:ini.cc:(.text+0xba9): undefined reference to `mxGetString_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x11d): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x145): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3dd): undefined reference to
>>> `mexPrintf_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x5c3): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x5db): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x6ea): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x914): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x91e): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x928): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0xe84): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1062): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x107a): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1238): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1242): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x124c): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1256): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1260): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x126a): more undefined references to
>>> `mxFree_800' follow
>>> : multiEzca.obj:multiEzca.c:(.text+0x1326): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1346): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x136c): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x138e): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1847): undefined reference to
>>> `mexPrintf_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x187f): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1e19): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1f51): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x1fe7): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x2063): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x322e): undefined reference to
>>> `mxCalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x335b): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x35e4): undefined reference to
>>> `mxMalloc_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x365a): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3662): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x39d7): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3ad4): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3b42): undefined reference to
>>> `mxFree_800'
>>> : multiEzca.obj:multiEzca.c:(.text+0x3b68): more undefined references to
>>> `mxFree_800' follow
>>> : ctrlC-polled.obj:ctrlC-polled.c:(.text+0x5): undefined reference to
>>> `utHandlePendingInterrupt'
>>> : mglue.obj:mglue.c:(.text+0x29): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x38): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x9c): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0xac): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0xbc): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0xd3): undefined reference to `mxCalloc_800'
>>> : mglue.obj:mglue.c:(.text+0xf4): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x100): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x10e): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x11b): undefined reference to `mxMalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x136): undefined reference to `mxGetString_800'
>>> : mglue.obj:mglue.c:(.text+0x156): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x165): undefined reference to `mxGetCell_800'
>>> : mglue.obj:mglue.c:(.text+0x1a9): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x1b8): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x1e4): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x214): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x241): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x24c): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x266): undefined reference to `mxCalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x2e4): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x404): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x41b): undefined reference to `mxGetString_800'
>>> : mglue.obj:mglue.c:(.text+0x510): undefined reference to
>>> : mglue.obj:mglue.c:(.text+0x581): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x58e): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x59b): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x5ae): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x5d5): undefined reference to `mxCalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x5fc): undefined reference to `mxGetM_800'
>>> : mglue.obj:mglue.c:(.text+0x60a): undefined reference to `mxGetN_800'
>>> : mglue.obj:mglue.c:(.text+0x617): undefined reference to `mxMalloc_800'
>>> : mglue.obj:mglue.c:(.text+0x632): undefined reference to `mxGetString_800'
>>> : mglue.obj:mglue.c:(.text+0x652): undefined reference to `mxGetCell_800'
>>> : mglue.obj:mglue.c:(.text+0x65d): undefined reference to `mxIsChar_800'
>>> : mglue.obj:mglue.c:(.text+0x699): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x6a6): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x6b3): undefined reference to
>>> : mglue.obj:mglue.c:(.text+0x6d9): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x6ea): undefined reference to `mxFree_800'
>>> : mglue.obj:mglue.c:(.text+0x71b): undefined reference to
>>> `mxCreateCellMatrix_800'
>>> : mglue.obj:mglue.c:(.text+0x732): undefined reference to
>>> `mxDuplicateArray_800'
>>> : mglue.obj:mglue.c:(.text+0x73f): undefined reference to `mxSetCell_800'
>>> : mglue.obj:mglue.c:(.text+0x759): undefined reference to `mxIsCell_800'
>>> : mglue.obj:mglue.c:(.text+0x76d): undefined reference to `mxIsDouble_800'
>>> : mglue.obj:mglue.c:(.text+0x8b5): undefined reference to `mxGetPr_800'
>>> Error 2
>>> On 18-12-2023 18:49, Freddie Akeroyd - STFC UKRI wrote:
>>>> Hi Bo,
>>>> Do you see the same error as Giovanni saw, or are you getting a different
>>> build failure?
>>>> Regards,
>>>> Freddie
- Re: LabCA for MATLAB Installation error boj via Tech-talk
- RE: LabCA for MATLAB Installation error Mark Rivers via Tech-talk
- Re: LabCA for MATLAB Installation error Michael Davidsaver via Tech-talk
Re: Question about cross compile of epics Ralph Lange via Tech-talk
<2024>
2025
<2024>
2025
