1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Linux for VME devLiv, mca libSIS38XX.a
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Rong Huang <[email protected]>
Cc: [email protected]
Date: Wed, 17 Jan 2024 14:53:43 -0800
On 1/17/24 12:51, Rong Huang via Tech-talk wrote:
Hello,
May I ask what kind of Linux that has support for VME devLib? Can I install some software to make a normal Linux support VME devLib?
Unfortunately, I am not aware of anything I would describe as "normal"
about VME support in Linux.  You may have a lot more work than you
expect here.  :(
To start with, can you describe your hardware?  What sort of VME cards
are present in your crate(s) ?
I would like to build mca/lib/liunx-x86_64/libSIS38XX.a. According to the notes in mca/mcaApp/SISSrc/Makefile:
# If your version of Linux has support for VME devLib uncomment following line
#LIBRARY_IOC_Linux += SIS38XX
In my $EPICS_BASE/include directory, and I find files of:
devLib.h
devLibVME.h
devLibVMEImpl.h
But that seems not enough, and the make of mca with option of "LIBRARY_IOC_Linux += SIS38XX" has errors of:
../drvSIS3820.h:208:3: error: ‘DMA_ID’ does not name a type
My system:
EPICS_base-7.0.7
mca-R7-9
linux_x86_64: Ubuntu 22.04.2 LTS
devLib2-2.12
Also tried:
EPICS_base_3.14.12.8
mca-7-8
linux-arm; RHEL
(no devLib2)
Thanks a lot,
Rong
RE: Linux for VME devLiv, mca libSIS38XX.a Mark Rivers via Tech-talk
Linux for VME devLiv, mca libSIS38XX.a Rong Huang via Tech-talk
Prev: Linux for VME devLiv, mca libSIS38XX.a Rong Huang via Tech-talk
Next: RE: Linux for VME devLiv, mca libSIS38XX.a Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
