1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Linux for VME devLiv, mca libSIS38XX.a
To: Michael Davidsaver <[email protected]>, Rong Huang <[email protected]>
Date: Thu, 18 Jan 2024 00:20:27 +0000
Hi Rong,
As I recall that SIS support on Linux was used by some sites that had an SIS PCI to VME adapter.  It let a Linux PC talk to VME.  I doubt if that is still in use.  The other way to do it is to run Linux on a VME CPU.  That has been done, but I don't know any site currently using it.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Michael Davidsaver via Tech-talk
Sent: Wednesday, January 17, 2024 4:54 PM
To: Rong Huang <[email protected]>
Cc: [email protected]
Subject: Re: Linux for VME devLiv, mca libSIS38XX.a
On 1/17/24 12:51, Rong Huang via Tech-talk wrote:
> Hello,
> May I ask what kind of Linux that has support for VME devLib? Can I install some software to make a normal Linux support VME devLib?
Unfortunately, I am not aware of anything I would describe as "normal"
about VME support in Linux.  You may have a lot more work than you expect here.  :(
To start with, can you describe your hardware?  What sort of VME cards are present in your crate(s) ?
> I would like to build mca/lib/liunx-x86_64/libSIS38XX.a. According to the notes in mca/mcaApp/SISSrc/Makefile:
> # If your version of Linux has support for VME devLib uncomment
> following line #LIBRARY_IOC_Linux += SIS38XX
> In my $EPICS_BASE/include directory, and I find files of:
> devLib.h
> devLibVME.h
> devLibVMEImpl.h
> But that seems not enough, and the make of mca with option of "LIBRARY_IOC_Linux += SIS38XX" has errors of:
> ../drvSIS3820.h:208:3: error: ‘DMA_ID’ does not name a type
> My system:
> EPICS_base-7.0.7
> mca-R7-9
> linux_x86_64: Ubuntu 22.04.2 LTS
> devLib2-2.12
> Also tried:
> EPICS_base_3.14.12.8
> mca-7-8
> linux-arm; RHEL
> (no devLib2)
> Thanks a lot,
> Rong
Re: Linux for VME devLiv, mca libSIS38XX.a Rong Huang via Tech-talk
Re: Linux for VME devLiv, mca libSIS38XX.a Michael Davidsaver via Tech-talk
Prev: Re: Linux for VME devLiv, mca libSIS38XX.a Michael Davidsaver via Tech-talk
Next: RE: Questions about creating a Model 3 Driver for stepper motor axis Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Re: Linux for VME devLiv, mca libSIS38XX.a Rong Huang via Tech-talk
