Hello, I'd like to ask you about mvme3100 and epics versions and synapses versions. First, we configured the motor control system using the mvme6100 and maxv controller. However, we want to build a new motor control system as the production of the mvme6100 is lost. Currently, the available cpu is mvme3100, and this cpu is compatible with version 6.9 of vxworks, so we want to select it. However, before I choose, I would like to ask for your advice if the mvme3100 model is also available in epics base 3.15.9 and synApps 6-1, and motor-R7-1. And, for MME6100, the clock count is 1.2Ghz, and for MME3100, the clock count is 500Ghz. The clock count is more than double, is there any problem with motor control? There are many things I don't know because I'm a junior in the field. Please give me advice and teaching. Best&Regards. Baeg
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
