1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: RE: Install EPICS on Raspberry pi and control motor
To: whitetiger1123 <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 30 Jan 2024 00:53:10 +0000
  • What kind of motor module should I use? motorPI is for raspberry pi?
You can use any type of RS-232 or Ethernet controller with the Raspberry Pi.  For example motorAcs supports the ACS MCB-4B serial controller, and Galil supports the Ethernet Galil controllers.
From: Tech-talk <[email protected]> On Behalf Of whitetiger1123 via Tech-talk
Sent: Wednesday, October 11, 2023 2:30 AM
To: [email protected]
Subject: Install EPICS on Raspberry pi and control motor
Hi, all. I have 1 question.
I want to study EPICS and motor control, so I’ll make a small independent control system with raspberry pi B3 Model.
Thanks for your help.
Best and Regards,
Baeg
Re: Install EPICS on Raspberry pi and control motor Pete Jemian via Tech-talk
Install EPICS on Raspberry pi and control motor whitetiger1123 via Tech-talk
Prev: RE: MAXnet ld:Can't open "omsAsyn.munch": No such file or directory. Mark Rivers via Tech-talk
Next: Re: Install EPICS on Raspberry pi and control motor Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Install EPICS on Raspberry pi and control motor whitetiger1123 via Tech-talk
