1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Build system issue
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 06 Feb 2024 14:08:46 +0100
I'm working on a device which has around 20.000 channels which have mostly very similar names. Therefor I created a perl script that auto generates some template files to be used by the IOC. How can I define a rule in the Db/Makefile that calls this script?
A simple
DB += db.template
db.template:
	perl script.pl
does not work. It complains that there is no rule to create ../O.Common/db.template.
Jörn
Re: Build system issue Simon Rose via Tech-talk
Prev: Re: EPICS on FPGA Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: Build system issue Simon Rose via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: RE: No CA connection from server to ioc Luchini, Kristi L. via Tech-talk
