1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller
From: Mrinal Bera via Tech-talk <[email protected]>
To: "Webb, Brad" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 22 Feb 2024 23:04:41 +0000
Hi Brad and Abdalla, Thank you for your template and protocol files. I had to modify the files a little bit to make it work for MPCQ Pump. Best regards, Mrinal > On Feb 22, 2024, at 6: 00 AM, Webb, Brad <webbsb@ ornl. gov> wrote: >
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Best regards,
Mrinal
> On Feb 22, 2024, at 6:00 AM, Webb, Brad <[email protected]> wrote:
> Hi
> At SNS we use the DIGITEL QPC Controller from Gamma vacuum.
> We use the serial interface via a digi/moxa.
> Attached is our streamdevice interface (i.e., xxx.proto and
> xxx.template)
> -Brad
> On Thu, 2024-02-22 at 00:50 +0000, Mrinal Bera via Tech-talk wrote:
>>  Did anybody write EPICS support for the following devices? 1) Gamma
>> Controller(https: //www. gammavacuum. com/products/digitel-
>> controllers/3335/digitel-mpcq?number=MPCQ1PS1U1SSNI&c=17669) 2)
>> Televac MX200 Vacuum Controller
>> 1) Gamma DIGITEL MPCQ Ion Pump
>> Controller(https://www.gammavacuum.com/products/digitel-controllers/3335/digitel-mpcq?number=MPCQ1PS1U1SSNI&c=17669
>> 2) Televac MX200 Vacuum Controller
>> (https://www.frederickscompany.com/products/mx200/)
>> Thanks,
>> Mrinal
>> Mrinal Kanti Bera, PHD
>> Beamline Scientist and Research Associate Professor
>> NSF’s ChemMatCARS, Pritzker School of Molecular Engineering,
>> The University of Chicago
>> 9700 S. Cass Ave Bldg 434D
>> Argonne, IL-60439
>> United States
>> Phone: +1-630-252-0472
record(stringin, "${P}:IP${N}:Model")
 field(DTYP, "stream")
 field(INP, "@gamm1.proto getModel(${ADDR}) GAMC")
 field(SCAN, "1 second")
record(stringin, "${P}:IP${N}:FirmwareVersion")
 field(INP, "@gamm1.proto getFWV(${ADDR}) GAMC")
record(ai, "${P}:IP${N}:Current")
 field(INP, "@gamm1.proto getCurrent(${ADDR},${S1}) GAMC")
 field(PREC, "0")
 field(EGU, "AMPS")
record(ai, "${P}:IP${N}:Pressure")
 field(INP, "@gamm1.proto getPressure(${ADDR},${S1}) GAMC")
 field(PREC, "0")
 field(EGU, "Torr")
record(ai, "${P}:IP${N}:Voltage")
 field(INP, "@gamm1.proto getVoltage(${ADDR},${S1}) GAMC")
 field(PREC, "0")
 field(EGU, "VOLTS")
record(mbbi, "${P}:IP${N}:Status")
 field(INP, "@gamm1.proto getPumpStatus(${ADDR},${S1}) GAMC")
 field(ZRVL, "0")
 field(ONVL, "1")
 field(TWVL, "2")
 field(THVL, "3")
 field(FRVL, "4")
#String Vals
 field(ZRST, "STANDBY")
 field(ONST, "STARTING")
 field(TWST, "RUNNING")
 field(THST, "COOLDOWN")
 field(FRST, "ERROR")
 #String Severities
 field(ZRSV, "NO_ALARM")
 field(ONSV, "MINOR")
 field(TWSV, "NO_ALARM")
 field(THSV, "MINOR")
 field(FRSV, "MAJOR")
record(ai, "${P}:IP${N}:PumpSize")
 field(INP, "@gamm1.proto getPumpSize(${ADDR},${S1}) GAMC")
 field(PREC, "0")
 field(EGU, "L/S")
record(ai, "${P}:IP${N}:PressureFactor")
 field(INP, "@gamm1.proto getPumpPressureFactor(${ADDR},${S1}) GAMC")
 field(PREC, "2")
record(stringin, "${P}:IP${N}:AutoRestart")
 field(INP, "@gamm1.proto getAutoRestartStr(${ADDR},${S1}) GAMC")
record(ai, "${P}:IP${N}:CurrentLimit")
 field(INP, "@gamm1.proto getPumpCurrentLimit(${ADDR},${S1}) GAMC")
 field(PREC, "0")
 field(EGU, "mA")
record(ai, "${P}:IP${N}:GetSetpoint")
 field(INP, "@gamm1.proto getSetpoint(${ADDR},${S1},${S2},${P},${N}) GAMC")
 field(PREC, "0")
record(ai, "${P}:IP${N}:Relay${S1}OnPressure")
 field(EGU, "Torr")
record(ai, "${P}:IP${N}:Relay${S1}OffPressure")
 field(EGU, "Torr")
record(ai, "${P}:IP${N}:Relay${S1}State")
record(calcout, "${P}:IP${N}:Relay${S1}OnCalc")
 field(SCAN, "Passive")
 field(INPA, "${P}:IP${N}:Relay${S1}OnPressureSetpoint")
 field(INPB, "${P}:IP${N}:Relay${S1}OffPressure")
 field(CALC, "0")
 field(OUT, "@gamm1.proto SetSetpoint(${ADDR},${S1},${S2}) GAMC")
record(ao, "${P}:IP${N}:Relay${S1}OnPressureSetpoint")
 field(FLNK, "${P}:IP${N}:Relay${S1}OnCalc")
 field(PREC, "2")
record(calcout, "${P}:IP${N}:Relay${S1}OffCalc")
 field(INPA, "${P}:IP${N}:Relay${S1}OnPressure")
 field(INPB, "${P}:IP${N}:Relay${S1}OffPressureSetpoint")
 field(CALC, "0")
record(ao, "${P}:IP${N}:Relay${S1}OffPressureSetpoint")
 field(FLNK, "${P}:IP${N}:Relay${S1}OffCalc")
 field(PREC, "2")
record(bo, "${P}:IP${N}:HighVoltageOn")
 field(OUT, "@gamm1.proto HvTurnOn(${ADDR},${S1}) GAMC")
 field(HIGH, "1")
record(bo, "${P}:IP${N}:HighVoltageOff")
 field(OUT, "@gamm1.proto HvTurnOff(${ADDR},${S1}) GAMC")
 field(HIGH, "1")
Terminator = CR;
#InTerminator = LF;
ReplyTimeout = 10000;
ReadTimeout = 10000;
#in "^[0-9]{2} OK 00 ([0-9]+.[a-zA-Z0-9-]+) (TORR|MBAR|PASCAL) [a-zA-Z0-9]{2}"
#in "%*s%*s%*s%s%*s%*s";
#in "\$1 OK 00 %s QPC %0<sum8>";
getModel
    out "~ \$1 01 %01.0<sum8>";
    in "\$1 OK 00 %/DIGITEL QPC/ %0<sum8>";
getFWV
    out "~ \$1 02 %01.0<sum8>";
    in "\$1 OK 00 FIRMWARE VERSION: %s %0<sum8>";
getCurrent
    out "~ \$1 0A \$2 %01.0<sum8>";
    in "\$1 OK 00 %e %*s %0<sum8>";
getPressure
    out "~ \$1 0B \$2 %01.0<sum8>";
getVoltage
    out "~ \$1 0C \$2 %01.0<sum8>";
    in "\$1 OK 00 %d %0<sum8>";
getPumpStatus
    out "~ \$1 0D \$2,00 %01.0<sum8>";
# ~ 08 11 1 00
# 08 OK 00 300 L/S 63
getPumpSize
    out "~ \$1 11 \$2 %01.0<sum8>";
    in "\$1 OK 00 %d %*s %0<sum8>";
    out "~ \$1 1D \$2 %01.0<sum8>";
    in "\$1 OK 00 %f %0<sum8>";
getAutoRestartStr
    out "~ \$1 34 \$2 %01.0<sum8>";
    in "\$1 OK 00 %s %0<sum8>";
getPumpCurrentLimit
    out "~ \$1 43 \$2 %01.0<sum8>";
getSetpoint
    out "~ \$1 3b \$2 %01.0<sum8>";
    in "\$1 OK 00 \$3,1,\$3,%(\$4:IP\$5:Relay\$2OnPressure)e,%(\$4:IP\$5:Relay\$2OffPressure)e,%(\$4:IP\$5:Relay\$2State)d %0<sum8>";
SetSetpoint
    out "~ \$1 3b \$3,1,\$3,%(A)e,%(B)e %01.0<sum8>";
    in "\$1 OK 00 %0<sum8>";
HvTurnOn
    out "~ \$1 37 \$2 %01.0<sum8>";
HvTurnOff
    out "~ \$1 38 \$2 %01.0<sum8>";
Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Smith, Martin via Tech-talk
Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Mrinal Bera via Tech-talk
Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Webb, Brad via Tech-talk
Prev: Re: Any chance people can get rid of this extra "feature" Johnson, Andrew N. via Tech-talk
Next: Re: EPICS PLC5 Support Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Webb, Brad via Tech-talk
Next: Re: [EXTERNAL] Epics support for DIGITEL MPCQ Ion Pump Controller and Televac MX 200 Vacuum Controller Smith, Martin via Tech-talk
